Curing fiberglass body - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2017, 03:03 PM
Dc309's Avatar
Last journal entry: Made some big changes.
Hi all, i just ordered my first fiberglass body. A 1923 C Cab. I keep reading that the fiberglass bodies will have to be cured, and to let sit out in the sun for 2 weeks. My question is i live in NY by the time the body gets here it will be here at the beginning of November should i just leave in garage till warmer weather? Is there a way to cure it in my garage? What temp needed to cure?
Thanks
Old 09-19-2017, 03:17 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
it is uv rays that cures it .
Old 09-19-2017, 03:20 PM
Dc309's Avatar
OK so temp dont matter to much? can i put a thin clear plastic over it to keep debris off?
Old 09-19-2017, 03:39 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That cover will block the UV.. some dust or dirt won't hurt the body..Just make sure the body s setting on a flat surface is all.
Sam
Old 09-19-2017, 03:47 PM
Dc309's Avatar
OK thanks guys. This is my first fiberglass body trying to learn every thing i can so screw ups are minimal.
Old 09-20-2017, 07:31 PM
Since this is your first fiberglass body I'll offer another piece of advice.
Before you do any sanding on the fiberglass, be sure to wash the body thoroughly. There can be mold release agent left on the gel coat and it will cause fish eyes in the paint. If you sand it without cleaning, the release agent can be forced into the gel coat.
I learned this the hard way on my T-bucket.
Old 09-21-2017, 03:29 PM
Dc309's Avatar
OK so here is what i got so far. Please correct me if i am wrong.
1. Wash body with mild soap and water.
2. Let body sit in sun for a few weeks to cure.
3. Wipe body down with a WATER based wax and grease remover.
4. scuff with 180-220 do not cut through gel coat.
5. fix pinholes with glazing putty.
6. Fix larger imperfections with body filler like rage.
7 prep for primer.
8 coat with epoxy primer, sand with 400
9. coat with primer surfacer/sealer block sand with 600.
10 ready for base coat.
Is this correct?
Thanks.
Old 09-21-2017, 04:37 PM
Wiki Edits: 3
I would not use any glazing putty as your rage will fix any pinholes. A good primer surfacer will also work on minor imperfections..
Sam
Old 09-21-2017, 09:47 PM
well dam u learn something new everyday....never knew the body had to cure. i thought they sit in a ware house some where for god knows how long till someone buys one then they ship one out...and i made my glass casket and dint hear anyone ever saying leave it cure in the sun for 2 weeks. fast glass or fritz, or batrods never said leave their kit bodies set in the sun .
fiberglass curing problem viperjack Body - Exterior 7 05-14-2017 10:16 AM
Curing fiberglass skip99 Body - Exterior 2 09-29-2014 03:38 PM
cardboard body to fiberglass body. ellist Body - Exterior 46 08-20-2008 07:11 PM
Fiberglass body help Craig Nadeau Body - Exterior 1 10-08-2003 07:14 PM
