Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Custom LED tail ligths, how to bundle led's?
Old 03-03-2009, 08:37 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
LED's are wired in parallel. You can hook almost an infinite number of them together as they draw very little current. Most all LED's for automotive use are rated for 12vdc. If you choose LED's of lower voltage rating you must drop the supply voltage down to their requirements. There are also hi intensity LEDs that are perfect for automotive use. As far as I am aware of they are available in clear, red, green, blue, and yellow. Here sre some sites that carry LEDs.
Mouser Electronics
Digi Key Electronics
Both sites do not have minimum order requirement and both have excellent web sites and paper catalogs.
Vince
