Cutting a Durablock ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2018, 08:22 PM
Has anyone ever cut one down to the size that they want ?
Old 08-06-2018, 08:49 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
Aw yeah, I cut my round and small long ones right out of the set's box. I think I used a box cutter type snap blade knife. Hacksaw probably works, too. Never cut one of the big ones but seen it done more than once.
The Following User Says Thank You to idrivejunk For This Useful Post:
Coodeville (08-06-2018)
Old 08-06-2018, 08:50 PM
From the looks of it, I thought it could be done. I'm going to cut one on my tablesaw
Old 08-06-2018, 08:53 PM
idrivejunk's Avatar
Grand Prix user
I would not advise using any power tool, being afraid of melting the material.
Old 08-06-2018, 09:08 PM
i have an old miter box. i'll use that
Old 08-07-2018, 07:59 AM
I use to do that years ago with the regular old 3M block, cut it with a hack saw. LOL
Old 08-07-2018, 02:19 PM
make sure you check the bottom of the Durablock for flatness - you'd be surprised
Old 08-16-2018, 12:44 PM
mitmaks's Avatar
Last journal entry: Grille
Why? I have a set of durablocks and some longboards and usually can find appropriate sized one for the job.
Old 08-16-2018, 02:28 PM
"Usually" is the magic word there. I have a box of blocks, rubber, foam, wood, some with some very odd shapes made for a specific job that I probably should throw away being I will never have the need for it ever again. But making a unique block for one job isn't a bad idea.
Old 08-16-2018, 04:25 PM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
Yes, I use a little band saw. I also make up my own blocks from a big sheet of neoprene foam by gluing two or more thicknesses together. A hard foam also works. Then there are paint stir sticks, lumber scraps from my woodworking box, etc, etc, etc
Old 08-18-2018, 09:44 AM
put up or shut up
having a less than perfect surface on the bottom of the block is less important than having good procedures and blocking skills. Depending on where you place your hands, the block is certainly bending and not straight. The benefit of having a slightly soft block to help with clogging outweighs the benefits of having a super hard straight block that clogs cause it's so hard. Obviously this is only true in a slight degree. If you have the touch you can get something at least factory straight with just the side of your palm and no blocks at all. That said, I still have one long hard block I call "The Truth Block" but love the feel of Durablocks.
I cut a bunch of Dura blocks. They are the best block sets you can buy. If you like the hook it paper the hook it versions stay a little straighter or stiffer at least due to the velcro.
Durablock - Doubts Leandro Body - Exterior 12 10-15-2012 08:16 AM
round durablock with metal rod in it tech69 Body - Exterior 3 06-01-2012 07:13 AM
Durablock set (biggest is 16") or a seperate 24"? JohnnyK81 Body - Exterior 2 01-25-2011 08:05 PM
Cutting windshields down 4senuff Body - Exterior 11 07-25-2005 04:42 PM
glass cutting Tom Body - Exterior 2 01-28-2002 12:51 PM
