Cutting springs question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2015, 07:06 AM
jseabolt's Avatar
Just as a general rule of thumb.
If you had a car and you wanted to lower it by cutting the springs, if you removed the spring from the car and removed 2" off the spring would this lower the car 2"?
Or do you have to take into account spring rate?
I've made the mistake a couple of times where I cut the springs on the car without disconnecting the front sway bar only to end up lowering the car more than what i intended to.
Old 07-22-2015, 09:12 AM
Only cut 1/4 to 1/2 coil off at a time until you get it where you want it. Cutting springs will also increase Spring Rate. And it will change geometry like lower control arms, which you want to maintain at a parallel/horizontal position relative to the ground.
Search this forum and Google for "cut mustang II springs" and you will get tons of info.
Old 07-22-2015, 09:27 AM
Old(s) Fart
Last wiki edit: Wheelbase database
The relationship between spring cut and car lowering will vary based on the suspension geometry, spring geometry, and spring rate. The only thing certain is that it is NOT 1:1. Typically cutting a spring 1" results in a greater than 1" reduction in height, due to the leverage in the suspension arm design. Since this is different for every car, there is no way to know how yours will react. As noted, it's trial and error. Unfortunately, that means a lot more time and effort on your part.
Old 07-23-2015, 11:45 AM
jseabolt's Avatar
I'm wanting to lower my Subaru Baja. It sits about 2 to 3" higher than a Legacy wagon (which it's based on). I haven't been able to determine if the springs in it are the same ones used on the Outbacks which sit higher.
Ebay is awful when it comes to cross referencing parts. One auction says the Baja and Legacy wagon use the same front springs but the Baja obviously sits higher. Then another guy's auction says Legacy springs won't even fit a Baja.
I considered just buying a new set of springs for a standard Legacy wagon but I'm not sure if that will give me the drop I am looking for. That's why I wanted to know about cutting the springs. If it doesn't drop the car, I can always take a coil or two off.
Some people have installed adjustable strut assemblies but $1000 is out of my budget. This is the ride height I'd like to go with:
On the other hand some people install spacers between the body and strut assemblies to raise their Bajas:
Years ago I ordered some new MOOG springs for my 68 Fairlane. I specified the engine size and without A/C (like that really matters on a car that size) only to find out when I installed them, it jacked the front end of the car about 4"!!! Maybe I got a set of big block springs by mistake.
The rear end was sagging to begin with. In the end I had to cut the front springs and install lowering blocks in the rear to get the car level.
Old 07-23-2015, 11:49 AM
Old(s) Fart
Kinda hijacking this thread, but since you asked...
If you are using ebay as a parts manual, you are in big trouble. About 90% of ebay ads will have incorrect applications. These ads are all written to generate clicks, not to be accurate. As for comparing Outback and Legacy springs, why not just go to the nearest dealership and look up the part numbers for the two applications. Either they are the same P/N or they are not. You'll have your definitive answer.
The Following User Says Thank You to joe_padavano For This Useful Post:
malc (07-23-2015)
Old 07-23-2015, 03:40 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Not always cause different vendors and different specs, SN cutoffs, and inventory control can make the PN different even if the part is basically the same.
Old 07-24-2015, 08:36 AM
StreetworksTech's Avatar
Supporting Vendor
NASIOC is an excellent community for Subaru information. I know there have been some people that swapped the complete strut assemblies front and rear into the Baja's from the 2000-2004 Legacy GT and they claim it rides nice but it's way too low. Brief search brought up that all subaru legacy strut assemblies should be a direct bolt on.
If you decide to cut your springs just make sure they will seat properly once cut. I know a lot of cars have a flat coil on top and bottom to make them seat. Some just come to an end and fit against the strut plates to prevent them from spinning. I know a couple of guys that have done this and did not pay attention to how they seat and the spring came out and stabbed their tires.
Old 07-24-2015, 01:04 PM
runn141's Avatar
yes, i wanted an inch drop in an s10 with a smallbock and i cut a 1/4 coil off. it reclocked the spring in the a arm enough to get it.
Old 07-27-2015, 10:10 AM
In reference to your Dreadnought-class Ford; Often when buying new springs, the car will ride high until the spring relaxes. I put new front springs in my transam about 5yrs ago and it sat like a Bi-plane for about a month. Man I was rippin' mad. I called Moog and insisted they were wrong. The tech patiently explained that they will relax some and it'll be fine. Grrr...but I didn't want Eibach sport springs, too low for our pothole-infested roads. Anyway, walked out of work one day and the car was sitting properly....weird but true.
Cutting Leaf Springs azlogger Suspension - Brakes - Steering 4 02-12-2013 08:29 AM
cutting springs oregon chevelle Suspension - Brakes - Steering 10 01-17-2008 07:19 PM
Cutting Springs 67camarokid Suspension - Brakes - Steering 11 06-01-2006 08:19 PM
Cutting springs? Longboard Suspension - Brakes - Steering 20 04-04-2006 02:52 PM
Cutting Springs ??????? Pac-Man Suspension - Brakes - Steering 1 02-02-2006 09:32 AM
