Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cylinder ridge an inch down in the cylinder. What gives?
Old 04-30-2009, 11:29 PM
DaSouthWon's Avatar
DaSouthWon DaSouthWon is offline
I put up the tools against$300
It appears that the ridge is below where even the oil ring would be when the cylinder is at tdc. It literally extends a good inch down from the top of the bore. The pistons sit .100 below the deck. I didn't want to pull this bottem end apart but I may pull that one piston out to see whats up.
