Sponsored Links | |||
All the combustion chambers looked like this:
![]() Plugs were the same color ![]() The bottom of the carb, top of the spacer, inside of the nitrous plate and the intake runners were this color: ![]() Ideas? ![]() |
up
Bent valves are almost always a problem of the springs loosing control (surging) which could also be part of the reversion problem seen with the intake. This problem can be very complicated involving push rod bending, rocker studs weaving around, rockers bending or not tracking straight, as well the the expected issue of the spring loosing control for a host of reasons. Some solutions can be 3/8s push rods even composite designs if you can afford it. The use of 7/16 studs with a girdle. Stainless roller rockers for additional stiffness and better tracking. Raised end guide plates to control the push rod higher up to the rocker so there are less angularity problems between the rocker and push rod. Additional spring pressure, though make sure you have adequate damping of the spring first before adding stffness, reduced weight of the retainer and lock assembly. Proper alignment of the push rod thru the rocker to the valve stem; the pushrod working at the slightest of angles is a reason for it to bend; in bending it acts like a spring becoming longer or shorter at a frequency that probably has nothing to do with the timing of the opening and closing cycle of the cam. Bronze guides or an alloy thereof are very helpful to insure that the stem and guide run tight without binding, cast iron against the stem often results in a loose clearance that lets the valve "orbit" and encourages grabbing the stem in the guide; always use a good hard chrome stem valve. Anyway this can go on for a long time. Bogie |
damn.... lol so basically im screwed? lol... What would be your 1st step?
next
Less cam. Hell, I run similar numbers in a 454 with 10-1 comp and a 800cfm Q- Bog duel plain manifold with 124cc chambers. And it's a monster 500ftlbs tq
Yes it pissed me off, but while scoring some quality time in a dino cell a guy (smart) was running impressive numbers (mouse 700 hp naturaly aspirated). He took the carb off for a swap and wouldn’t you know it he had filled half of his plenum with epoxy!!! ![]() Lift and lose Last edited by RexRat; 11-25-2007 at 09:18 PM. |
If it's reversion why do the intake runners look clean, at least in the picture they do apprea quite clean?
That whole head surface and all the combustion chambers basically look kind of like a mess. With nitrous being way too rich can be as bad, or worse as being too lean. I would most certainly inspect all the pistons looking for crushed skirts and ring lands. I'd also measure the bores. I'd suspect your rings are shot as well. Just a guess. When you have the heads rebuilt you really need to clay the tops of the pistons to check PV clearance. |
It's all motor.... No nitrous being used at all yet.. Pistons are fine and rings all are within 10psi
Would driving down the track after that valve bent cause the black in the carb & spacer?? Since it was the intake valve the exhaust would be going up inside the intake correct? The P-V clearance is great... With the bent valve it still didnt hit, lol.. Ok ANYBODY have a guess at why the combustion chambers and plugs are light tan/yellow??? It's 104 unleaded fuel if that helps! I APPRECIATE THE HELP GUYS! ![]() |
Bogie |
Yes, before I bent the valve and there is no way to tell now unless I pull the short block and that isnt happening...
The piston had a VERY small scuff and after I cleaned the carbon I could BARELY see where it hit... ![]() I know what a broken piston looks like... Mine are ok unless your going somewhere with this and then I will post up a pic to satisfy you.. ![]() |
![]() What about the color of the plugs bogie? any idea? looks to ME like burnt water? ![]() |
What were you running for fuel?? That color in the chamber is not all that unusual for some race gases, especially if it's leaded fuel. Might be a bit rich but that's all.
Reversion is not at all uncommon, and will happen in a perfectly functioning motor. It's a combination of things, intake and exhaust timing, pulse waves bouncing back through the cylinder from the exhaust, which will end up in the intake if the pulse arrives in the cylinder during overlap. You definitely have a valvetrain issue to solve(weak springs), but the reversion probably has little to do with it. |
I run 104 unleaded Sunoco fuel
So the yellowish color is from the race gas? If so then Im not worried but the plugs are usually brown/black and now they are white/yellow? ![]() |
Recent Engine posts with photos |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Camaro VATS ignition and column | RockinLocks4u | Electrical | 9 | 02-03-2005 10:34 PM |
Black Paint Prep | Ron M | Body - Exterior | 1 | 08-22-2004 01:38 AM |
verbal description of raven black as compared to black | Dubz | Body - Exterior | 5 | 02-24-2004 01:01 PM |
Black is black? | dh79 | Body - Exterior | 5 | 02-07-2004 05:38 AM |
Plugs | DoubleVision | Engine | 5 | 05-06-2003 04:42 PM |
