DARK brown--BLACK plugs SBC - Page 9 - Hot Rod Forum : Hotrodders Bulletin Board
  #121 (permalink)
Old 01-15-2008, 12:15 PM
Bogie... Somehow or another I have been saying my cam was retarded 4* well it's ADVANCED 4* not retarded... I just looked at the crank gear and it's in the triangle hole = 4* Advanced...
Does this change anything?
  #122 (permalink)
Old 01-17-2008, 03:43 PM
ttt
bogie? anybody?
  #123 (permalink)
Old 01-17-2008, 04:42 PM
Originally Posted by Joshua Lee
ttt
bogie? anybody?
I'm here, Chain stretch and 4 degrees retarded could cause these collisons. But I'm troubled by the combination of opposites. I don't have an answer, but it bothers me, I need to mock up an engine and cogitate on the possibilities.
Bogie
  #124 (permalink)
Old 01-17-2008, 04:45 PM
Sbc
Dude take that thing apart and inspect all aspects. There is a lot of literature on the subject.
I think Bogie was getting at that your main or journal bearings may be thin. Based on the fact that the engine has a lot of heavy use on it many things can be wrong.
Many of the possible operations such as checking for piston to valve are on this thread. But the first thing you should do is freshen up the bottom end. I will look over your input on this thread and sum up if you want but you should use your powers of deduction and get wrenching!
  #125 (permalink)
Old 01-25-2008, 01:20 PM
If the bearings were thin the cap would be loose... It wasnt, the bearings look fine so assuming the heads check out ok... Im at another stoping point
  #126 (permalink)
Old 02-02-2008, 11:16 AM
Well, I just cleaned off #6 and the Exhasut valve deffinatly hit, it dented the piston..
  #127 (permalink)
Old 02-02-2008, 02:05 PM
nitro_baller4692's Avatar
floppers forever
has anyone thought that the cam may have twisted.
sorry but 9 pages and we haven't found the problem
  #128 (permalink)
Old 02-02-2008, 07:09 PM
Ok.....
If the heads show up good, Im gona clay the pistons and if that shows up good Im swaping timing chains and claying the pistons again and putting it back togather...
  #129 (permalink)
Old 02-03-2008, 09:12 AM
I will check out all that.... I appreciate the help man, I totally forgot this post was about the carb being ritch, lol...
Camaro VATS ignition and column RockinLocks4u Electrical 9 02-03-2005 09:34 PM
Black Paint Prep Ron M Body - Exterior 1 08-22-2004 12:38 AM
verbal description of raven black as compared to black Dubz Body - Exterior 5 02-24-2004 12:01 PM
Black is black? dh79 Body - Exterior 5 02-07-2004 04:38 AM
Plugs DoubleVision Engine 5 05-06-2003 03:42 PM
