Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DARK brown--BLACK plugs SBC
Old 11-13-2007, 07:47 PM
Chevrolet4x4s Chevrolet4x4s is offline
Last wiki edit: How to title a hot rod
What is your vacuum at idle?Your power valve should be 1/2 of your vacuum at idle so if its 10 inches of vacuum you need 5 power valve do you have the power valve check ball?(if the carb is post 1992 it should be in there from the factory)
Shane
