The Day's Work (pic dump) - Page 158 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
View Poll Results: How often would you like this thread to be updated?
Daily 3 100.00%
Weekly 0 0%
Monthly 0 0%
No change needed 0 0%
Other (please specify) 0 0%
Voters: 3. You may not vote on this poll
  #2356 (permalink)
Old 03-23-2020, 06:37 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
He has the tunnel going too, didn't make it into the pic. Showing dash bracing. He asked if the body had to come off to get the firewall out. Well, yeah now it does. I advised that he just cut it in half, take it out and use it as a pattern. And thats why I left it flat.
Had hood set up on the truck this morning after finishing fender mount tabs. Couldn't fit boards with body blocked up so took the cab off and did some easy stuff thats easy to reach and needed doing-
Yes I will be shaving the cowl vent. I am assuming that blasting will be part of this deal... at whatever point it is sensible to do that.
The Following 3 Users Say Thank You to idrivejunk For This Useful Post:
123pugsy (03-23-2020), Gearhead Poppa (03-24-2020), Too Many Projects (03-23-2020)
  #2357 (permalink)
Old 03-24-2020, 05:57 PM
idrivejunk's Avatar
Grand Prix User
Mike's model A tunnel in the works-
My F1 cowl shave, also in progress-
I did make some bend adjustments with the setup shown above to fine-tune the patch's front edge at hood gap. But after initial rolling of the light step shown on the patch, most of the bend was done by tipping a few passes with the same rollers to bend, then chasing with loose english wheel and flat anvil for uniformity. Jaws for the finishing touches to the contour. Of course vise and anvil were key players along the way as well.
Before any of that though, I english wheeled the patch to get it laying down against the cowl with proper-ish contours.
Left some of the old channel at front, enough so that next I can knock it forward against the patch then cut and tack for a butt in the vertical flat. Then I'll recheck hood fit and go for it.
Gearhead Poppa (03-25-2020), John long (03-24-2020), Too Many Projects (03-24-2020)
  #2358 (permalink)
Old 03-24-2020, 06:13 PM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Looks good.
The Following User Says Thank You to 123pugsy For This Useful Post:
idrivejunk (03-24-2020)
  #2359 (permalink)
Old 03-25-2020, 05:55 AM
idrivejunk's Avatar
Grand Prix User
Thanks. We just don't know any better than to keep trying.
  #2360 (permalink)
Old 03-25-2020, 09:36 AM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
That's all any of us can do.
One day at a time, 1 foot in front of the other...keep on keepin' on...
The Following User Says Thank You to Too Many Projects For This Useful Post:
idrivejunk (03-25-2020)
  #2361 (permalink)
Old 03-25-2020, 09:16 PM
idrivejunk's Avatar
Grand Prix User
You got that right.
The Following 4 Users Say Thank You to idrivejunk For This Useful Post:
123pugsy (03-26-2020), Gearhead Poppa (03-26-2020), John long (03-27-2020), Too Many Projects (03-25-2020)
  #2362 (permalink)
Old 03-26-2020, 05:43 PM
idrivejunk's Avatar
Grand Prix User
This is why before I shape something, I clean and sand-
Make mine HEI with carbs please-
Best tails I've seen on bugs-
Looks like it should, better, now-
123pugsy (03-27-2020), Gearhead Poppa (03-26-2020), Too Many Projects (03-26-2020)
  #2363 (permalink)
Old 03-27-2020, 05:57 AM
idrivejunk's Avatar
Grand Prix User
Raise your hand if you feel like the cab back wall is smashed now.
  #2364 (permalink)
Old 03-27-2020, 06:42 AM
I know NOTHING !!
idrivejunk (03-27-2020)
  #2365 (permalink)
Old 03-27-2020, 08:03 AM
idrivejunk's Avatar
Grand Prix User
Pulse detected!
Of course its merely an optical illusion.
I'll have to show the setup under there, missed getting a pic of it. Rest assured that it is supported and protected even if slid around on the floor. And believe it or not, it sits perfect and doors work even without the high bar. That is there because rockers are about to be scrap.
  #2366 (permalink)
Old 03-27-2020, 08:26 AM
I hear a Popeil slice and dice running...
  #2367 (permalink)
Old 03-27-2020, 10:37 AM
idrivejunk's Avatar
Grand Prix User
I had it set to julienne but new ones are in like Errol Flynn.
That was about as hard as a boiled egg.
The Following User Says Thank You to idrivejunk For This Useful Post:
Gearhead Poppa (03-27-2020)
  #2368 (permalink)
Old 03-27-2020, 09:02 PM
idrivejunk's Avatar
Grand Prix User
One more dump before bed, emptying the bag o' pix... is there any more toilet paper?
Same thing but hosted by blog-
What I did to keep the back of the cab (just barely) off the floor is tack tubing to the skin at the bottom seam and at bottom of back window. That one has angle connecting it also to the bottom of the windshield bed by way of the top of the back window. If you followed that, you may also remember when I tried to wheel out a model A side in one piece. That dished and mangled piece of scrap serves as a skid plate connecting the upper and lower horizontal tubing, and both tubes are juuust big enough the let the cab wall hang free.
For the record, however... there is a repaired caved spot on the upper portion of the cab back wall, below the window on one side. You guys will crap moon rocks when you see how much filler and rust I will be dealing with. But I am at a point where I can set the cab down now and proceed. Pan and braces are back in now but no pic, got carried away cleaning up and thinking about food and plumb forgot.
But the pan fell right back into the same exact spot with the new rockers. There will be copious more hacking to do hidden hinges and bear claws, so no shortage of gore yet. Figure I best just keep it coming while everyone washes their hands.
This here was took after making holes for, but before screws. Five at front corners, six at rear. All good and tight. Just doing that started to square up cab corners.
The cologne zone-
New lunchandstuffbox from junk, definitely mine. Marked like my tool box and cart.
123pugsy (03-28-2020), Gearhead Poppa (03-28-2020), Too Many Projects (03-28-2020)
  #2369 (permalink)
Old 03-28-2020, 04:58 AM
123pugsy's Avatar
Wiki Edits: 29
Cool box. Most men ain't got square nuts.
idrivejunk (03-28-2020)
  #2370 (permalink)
Old 03-28-2020, 07:41 AM
idrivejunk's Avatar
Grand Prix User
Beats a hotbox. At least theres a pair. I think I have a whole square socket set .
Pic swap...change your last pic sqzbox Hotrodders' Lounge 1004 11-19-2018 05:56 PM
Dump dump dump.... bowtiebabe72 Hotrodders' Lounge 22 09-27-2004 08:16 PM
The dump- save it or dump it? ChevelleSS_LS6 Hotrodders Site Problems 19 06-07-2004 08:43 PM
The Dump is a Dump Kevin45 Hotrodders' Lounge 10 12-30-2003 09:10 PM
Body work is on hold Just a beginning pic of my car 406chevelle Hotrodders' Lounge 1 10-06-2003 11:22 AM
