Disk Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2018, 10:04 AM
Last journal entry: 1971 Camaro
Disk Brakes
Does anyone know if there is a Disk Brake kit that would work on a GM 8.5 rear end out of a 2002 S10? It had Disk Brakes just want newer stuff ie Wilwood or so.
Old 11-28-2018, 12:53 PM
delawarebill's Avatar
disc brakes
i put in ... "disc brake kit GM 8.5 rear end out of a 2002 S10"
and it came up with some on google.
Old 11-28-2018, 04:57 PM
64nailhead's Avatar
If you want a bolt on kit, then it depends whether your S-10 8.5 was originally a drum or disc setup. Both are available and your limit will be wheel diameter. If it was a drum setup, then any kit that will work on a 7.5 S10 rear will work on the 8.5 because the flanges are the same.
If you can do a weld on kit, then the sky's the limit IMO.
What is your wheel diameter? Tell us some about the vehicle.
Old 11-29-2018, 08:15 AM
Ford 8.8. Unless your 8.5 is already modified internally.
Disc make for easier maintenance and stay colder on the track. As well as some unsprung weight reduction in most cases.
But, if you want better breaking as daily driver drums will deliver better stopping then disc and are less prone to sticking pins or seals rupturing.
good disk disk breaks system nskeeter99 Suspension - Brakes - Steering 0 10-29-2011 05:35 PM
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 12:09 PM
oem MC and prop valve on disk/disk nskeeter99 Suspension - Brakes - Steering 1 07-10-2009 10:07 AM
disck/drum to disk/disk tomthecomic Suspension - Brakes - Steering 5 10-29-2007 09:53 PM
REAR DISK BRAKES reggiesr Suspension - Brakes - Steering 5 08-05-2007 08:40 AM
