Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DIY air compressor
  #19 (permalink)
Old 12-21-2007, 07:11 PM
matt167 matt167 is offline
Wiki Edits: 31
Originally Posted by oldred
Two tanks that size should work quite well for the size compressor you are talking about but why do you want a gas engine? If the reason is for mobile use then I would suggest just using one of those tanks but if it is to be stationary then you can use both but you would then be much better off with an electric motor, much simpler to set up and a heck of a lot cheaper to operate.
no 220V and it would be hard to run it.. possible but the lawn would have to be dug up,and being in town theres codes ect.... I'm pretty sure we have a 60 amp 220 service in the house we could tap off of. only 220v appliance is the stove.. I guess 220v electric is possible
