Do I Go thru Brick or Mortar? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2017, 06:51 PM
rdobbs77's Avatar
Huge Guns N Roses Fan
plan to build a work bench in my new garage. Have a brick wall that i'd like to affix a 2x4x8 to. Have the hammer drill option, plan to buy a masonry bit, and will probably use tapcon screws. Do i go thru the brick itself or mortar? I'm thinking brick. Need advice on which way to go,
Old 05-12-2017, 07:05 PM
dusterdude3404's Avatar
Right or wrong,i went into the mortar
Sent from my R1 HD using Tapatalk
Old 05-13-2017, 07:24 AM
fat tire's Avatar
fat tire
working as a carpenter helper, I was always told to try to avoid the joints and hit the brick or block
Old 05-13-2017, 07:55 AM
As an old telephone man you will find the anchors in the brick will be stronger but MUCH harder to drill. Also, it will depend on the quality of the morter, how well they will hold.
John
Old 05-13-2017, 08:48 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Go through the brick if at all possible . The mortar will be the weakest part of the wall.
454 RATTLER
Old 05-13-2017, 09:39 AM
rdobbs77's Avatar
Thanks guys, brick it is,
Old 05-13-2017, 10:14 AM
ogre's Avatar
the 'Duracell Project'
neither. a workbench should not hang on a masonry wall
a workbench should have 4 legs and not be attached to the wall
Old 05-13-2017, 01:30 PM
bob1964's Avatar
Last journal entry: 80 Z-28
I would hope that you plate it on the outside and yes threw the brick. I have always ran a plate on the outside so that it gets spread out, bolts at top and bottom. Mortor gets dry and falls apart over time , so it's a weak point .
Old 05-13-2017, 05:07 PM
fat tire's Avatar
fat tire
doesn't matter as long as there is a vertical leg(s) under the wall attached 2x4.
you don't have to have a free standing work bench
How much to brick a house? HotRodMan Off-Topic 3 01-19-2012 01:09 PM
355 pops/misfires and hits a brick wall at 4500 jarrettandroski Engine 72 09-27-2009 09:33 PM
Painting brick 428ho Garage - Tools 15 07-11-2006 11:55 PM
MadMax hits a brick wall. 87442lover Hotrodders' Lounge 4 06-24-2004 05:54 PM
