Does anyone make a 12:00 timing tab for SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2010, 08:31 PM
I'm building a 350 and the 6 3/4" balancer I have shows top dead center at about 12 or 12:30 or so when I eye ball it. The stock timing cover has a timing tab welded up top, but it's in bad shape so I purchased a after market cover. I also bought an after market timing tab that was listed for a 6 3/4" balancer, but it attaches over at about the 2:30, so it's way off. I thought about using timing tape and locating it at the new tab. But with an AC compressor and power steering attached on that side I'm not sure I would be able to see it once everything mounted up.
Does anyone make an after market timing for balancers that have their top dead center mark up top? Seems to be a lot of engines set up that way.
Old 02-03-2010, 11:59 PM
JeffB's Avatar
Helpful info
Go to Google and type in Professional Products,when the list pops up click on the harmonic balancer,it will take you to a PDF file.On the right side of the text under notes it explains the SBC timing marks and the tabs you can use.The balancers they have available come with both sets of marks and are much easier to read than a stocker and almost the same price.
Old 02-04-2010, 10:58 AM
All it tells me is they have a balancer that includes a mark for 12:00. It doesn't mention any tab that will work with the stock balancer. I was hoping there was a solution that didn't cost $150.
I can't believe there isn't anything out there for the huge number of small block chevys made from 84-95.
Old 02-04-2010, 01:33 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
A stock timing cover from around 1979+
And actually, I have found these easier to read than the 2:00 timing tabs.
Point the light straight down near the water pump and you have it.
Old 02-04-2010, 03:14 PM
JeffB's Avatar
OK,I will make it a little easier and it won't cost $150 either.Click on www.summitracing.com and at the upper left in search put this part number in,PFS-80000 .Now you already have an aftermarket pointer so you are getting closer,1984-95 350 Chevys have the 12 o'clock pointer this balancer has both early and late marks so when you install it on your new timing cover TDC will be around 3 O'clock with the pointer you have.Could be worse, 302 aka SBF Fords had 3 different timing marks.
Old 02-04-2010, 04:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cadillacs have 6 different combinations of tabs to dampers!
I would first DETERMINE TDC then MAKE A TIMING TAPE.
Permanently mark the damper at TDC, aligned to the timing tab you have, or which ever one you want to use. Lay the timing tape on, aligned to the "new" TDC and you're good to go.
If no tuning for total advance is needed, or you have a dial back timing light, skip the tape.
Old 02-04-2010, 07:35 PM
boatbob2
Timing Tab.....
HI,take a bent wire,using one of the timing cover bolts,bolt the wire,bend it to where TDC is,paint the wire white...go for it.
Old 02-04-2010, 09:44 PM
Boatbob 2 is the winner of todays quizz... Try a 3/32 309 ss. welding rod. Grind a point on the pointy end
Clint
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 10:48 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 41 10-25-2007 12:23 PM
what side is timing tab on? leastbay Engine 14 08-21-2004 02:54 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
SBC Timing indexing a unmarked 4.25 blower hub and custom tab 614streets Engine 9 06-14-2003 04:26 PM
