Dragging rear brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2018, 05:22 AM
I have four wheel disc brakes on my 70 Mustang and it seems like the rear brakes are dragging.
I installed a new Wilwood master cylinder and adjustable proportioning valve.
I have checked my master cylinder pushrod several times so I am pretty sure it is correct.
If I filled my master cylinder with to much brake fluid would that cause the brakes to drag?
Old 07-23-2018, 09:58 PM
No. Are your brakes boosted? Do you have a disc/disc master cylinder? If you have a disc/drum master cylinder than can cause brake drag.
Old 07-24-2018, 05:00 AM
No the brakes are manual not power.
I do have a disc/disc 15/16" bore Wilwood master cylinder.
I readjusted the brake pedal pushrod again and it is marginally better. Took the car on a 500 mile round trip right after July 4th no problems. But last weekend went about 15 miles and the right rear was dragging when i backed up.
Old 07-24-2018, 05:02 AM
Rose_419
Ebrake is not hooked up.
Old 07-24-2018, 06:31 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Sounds like the hardware isn't pulling the shoes away or holding the shoes from the drum.
A failing softline is a common issue with that symptom too. Usually it's worse after a hard brake episode.
Old 07-24-2018, 09:00 AM
PHWOARchild's Avatar
Modern rear-disc brakes depend on the use of the parking brake once in a while to keep everything moving. I would look for a sticky caliper first, also the rear hose as mentioned earlier. Lube any metal-to-metal surfaces with a high temp white grease.
Old 07-24-2018, 09:01 AM
I have four wheel disc brakes on the car
Old 07-24-2018, 10:39 AM
Check the flexible rubber brake hose that goes to the rear end. Sometimes the ID of the hose swells shut. Under brake pressure, fluid gets through the hose, when releasing the brakes, the fluid doesn't return to the master cylinder. This effectively keeps the brakes on. Disconnect both ends of the hose and try to blow air through it. If you have trouble getting air through it, replace the hose.
Old 07-24-2018, 11:11 AM
And they look perfectly fine on the outside most of the time. I had one in a customer's GM car years back, had to dissect the hose to find the restriction.
Front Disc Brakes Dragging jayd_2 Suspension - Brakes - Steering 12 04-15-2013 12:31 PM
Dragging Brakes Bad 57 Suspension - Brakes - Steering 9 01-12-2012 02:13 PM
Dragging brakes? FrankR Suspension - Brakes - Steering 2 12-06-2005 09:20 PM
76 Monte whose "A_ _ is dragging bigjoedo Suspension - Brakes - Steering 8 05-19-2003 08:21 PM
Anti-lock rear brake dragging Hotrod Rudy Suspension - Brakes - Steering 5 03-15-2003 11:28 AM
