Sponsored Links | |||
Looks like pretty standard stuff what are you trying to do/fix.
You want dropped spindles ? ^^^^^ Do not think you will find those for an early model front axle. Look closely you will understand why ^^^^^^^ The are mostly for later/newer independent suspensions. I do think the fuel pump is not mounted correctly LMAO Pep Last edited by rip-tide; 09-28-2019 at 06:32 PM. |
You have 49 to 54 Chevy car spindles, or possibly the original 41 truck spindles, in any case there is no dropped spindles for either application. You could dearch the springs possibly.
Not a chance how do you figure that? Pep |
I had the caliper replaced at a rod shop here in my town after it locked up at their shop. He mentioned a Camaro (not sure what year) if my memory serves me correctly. That's was like 10 years ago though, so I dont remember.
You're not going to find drop spindles for beam axles....when they want more drop they replace the tube axle with one having more drop, or heat and bend more drop into an I-beam axle, or re-arch the springs/reverse the spring eye. Dropped spindles are strictly an independent suspension thing. |
Loosing a couple of those leafs or installing super slide springs will drop that a bit.
POSIES Rods and Customs – Super Slide Springs – Street Rod Parts – Hot Rod Parts – Truck Parts – Ford and Chevy Suspensions and Chassis Parts » Super Slide Springs To loose around another inch you can install some spring sliders in place of those shackles. Now these are a maintenance item. The HDPE (like $5 per side) will need to be replaced from time to time. But the sliders allow for a flatter spring and allow for some drop while reducing "twist". Below is a video showing them going across uneven terrain. Between the flatter springs and the sliders that front end should drop around 2". |
don't u just love it when someone builds a custom car and does NOT maintain a book with parts and part numbers... ALLLLLL my builds i maintain a book... my memory sucks and in the last 3 cars i sold the new owners jumped up/down when i showed them the book.. if i sell the mustang i am thinking of just buy'n a finished model A rod.. but if no book.. no sale either...
No way is someone going to get those on a front end. Want to lower the front end, beyond the axle drop?
Cut the cross member out and re-wield it higher up into the frame. Dropped axle, * notice the shackles Sliders seen at the rear of the leaf spring Attempting to keep conversation apples too apples Pep |
more info ? Ford chevy car or truck
Sid had a lot of info that was published in magazines / research sid. various places .
https://droppedaxles.com/tech-articles years ago I put olds spindles on a ford type tube axle. new bushings reamed to fit ford kingpins. Amc bolt on spindles; lots of measurements needed,,, king pin to spindle stub angle ,,,kingpin dia and length ... steering arm clearance. etc. |
I left this out, top picture shows the cross member. Moved and re-wielded flush with the top of the frame rails, 2'' drop there
Pep |
OP front springs are longitudinal not transverse.
Missed that, reviewed the pictures, yes #2 show it.
thanks Pep |
Recent Suspension - Brakes - Steering posts with photos |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
