Drum brakes/51 dodge Coronet - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2018, 06:04 PM
I rebuilt my front wheel cylinders on my 51 dodge Coronet, put new brakes shoes on and tuned the drums. My passenger side drum won't go on all the way. I played with the adjustments on the cams and I can get it to go on a little further but not all the way. Could it be due to a warped drum? That wheel and one of the cylinders was froze up when I got the car.
Old 09-24-2018, 06:12 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
If you had the drum turned, it is not warped, it is round. It is likely that you don't have the shoes fully retracted.
If all else fails, order a reprint of the Genuine Factory Dodge Service Manual for 34 bucks. Best deal on the planet...…
https://www.faxonautoliterature.com/...int-P9262.aspx
This is the same manual that dealer mechanics would have used when your car was new.
Old 09-25-2018, 08:01 AM
S10xGN's Avatar
Gotta love a turbo!
With no fluid (or air) in the system, the springs should fully collapse the wheel cylinder prongs, allowing the shoes to fully retract. Open the bleeder and see if it helps?
Russ
Old 09-26-2018, 09:06 AM
Cridder's Avatar
Vd=0.7854B2S, CR=Vd+Vc/Vc
Last journal entry: 310 Small Block Chevy
Adjuster at the bottom of the shoes too far out?
'51 Dodge Coronet - slow build Empty_Wallet Projects/Builds/My Ride 7 03-28-2017 11:54 PM
Power Brakes upgrade - what is the reason for disc/disc, disc/drum & drum/drum JohnnySkills Suspension - Brakes - Steering 2 10-20-2012 08:44 PM
51 Dodge Coronet front clip swap Sinner Suspension - Brakes - Steering 4 01-15-2006 10:06 PM
51 Dodge Coronet Temp Gauge? dion Hotrodders' Lounge 0 07-11-2003 01:39 PM
