EDP coating, remove all or just scratch it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2006, 03:28 PM
BIGSKY's Avatar
See project in Photo Album
I have purchased a fender and two boxsides for my 71 C-10 project and wonder if I need to remove all the black EDP coating before laying down my epoxy primer? About 1/4 of the bedsides are already down to bare metal where I shaved the marker lights and stake pockets. Also what about the backside of the new parts; I planned on epoxy, then urethane build primer and paint just like the exterior, so should those hidden areas be sanded down to metal also?
Old 11-27-2006, 05:19 PM
we don't remove it from new parts. I'd just sand and then epoxy. Its easy to go through the coating in areas if you are machine sanding and not scuffing, so it normally gets primed. You could probably even paint right over sanded ecoat on inner areas if you wanted if you didn't go through. But Taiwan parts sometimes will come with a cheap black primer on it rather then a e coat. Wipe it with some lacquer thinner and if it doesn't remove it, I then think you will be fine sanding and epoxy. Some 320-ish dry and a scuff pad for hard areas, epoxy seal, paint should be plenty good for inner areas for most. Some probably just use a scuff pad the inner areas though. If you spray those inner areas soon enough, don't have anything to fix there, and get the epoxy to lay out well, then you could shoot your paint without sanding them again.
Old 11-28-2006, 12:07 PM
BIGSKY's Avatar
That is what I figured, because body shops can't spend all that time sanding off e coat. I agree, build primer on the backside of the parts is probably overkill too. I have had good luck with my epoxy finish, so I can probably just paint over that after a scuff. Thanks!
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 9 05-13-2012 06:07 PM
Using a Grinder to remove paint duallybuster Body - Exterior 16 07-30-2006 10:17 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
C6 Installation Trucknut Transmission - Rearend 6 01-18-2006 05:01 AM
Header Clearance Issue/Question About Damaging Ceramic Coating. Ghetto Jet Engine 8 10-09-2004 12:45 PM
