Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Electric fuel pump
Old 11-01-2018, 08:06 PM
chasracer's Avatar
chasracer chasracer is offline
True Hotrodder
Basic use, the Holley series are dependable and easy to rebuild later on. For performance use, we prefer Aeromotive or Magna Fuel. The only electric pumps I have ever had issues with were the Barry Grant stuff (out of business) and the Stewart Warner ones. SW units tended to burn up rather quickly. Make sure you use a filter in front of the pump, preferably sitting downward from the tank pickup. Also, if this is a street ride, a piece of tire sidewall makes a good vibration insulator - (also works well as replacement rubber for body mounts).and runing the power to the pump through a 30 amp relay will help the pump deliver it's full potential.
