Electric power steering: 1933 chevy coupe - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-27-2015, 06:19 PM
Originally Posted by OneMoreTime View Post
Since you have the MII rack now you may be able to change it out for a power rack. Check with Speedway and take the end to end measurement to make sure the new rack bolts in. Also check the measurements on the mounting bolts. On the engine assuming you have an sbc you will need a pump which ca be sourced from a wrecking yard and the hoses. you will need a restrictor to allow the proper pressure from the sbc pump to the ford rack.
Depending on your skill level this can be weekend bolt on project. I have no clue as to what may be needed on you particular rig as to welding a fabrication..
Sam
Sam still new at this I should have told you my project is a 1933 chevy egale coupe /L46 corvette engine
Phil
  #17 (permalink)
Old 01-15-2019, 11:31 AM
Ralfareno's Avatar
1937 Ford Pickup
Unisteer electric steering
Hello Sam G, How did you go about installing the unisteer electric power steering into the steering colunm. Thanks
  #18 (permalink)
Old 01-18-2019, 04:56 PM
Ralfareno's Avatar
1937 Ford Pickup
Hi Joe G
Can you tell me how you did the unisteer install. I need detailed instructions for this conversion. I have an Ididit steering column which I think is similar to a Flaming River column. My is a tilt column though. Thanks
Replacing a manual steering rack with a power rack on my 1933 chevy dmans Suspension - Brakes - Steering 2 12-05-2014 01:11 PM
Intro: 1933 Chevy coupe john56h Introduce Yourself 11 03-11-2008 06:08 PM
1933 chev 3 window coupe Knightrider Body - Exterior 1 01-30-2003 07:12 PM
