Electric power steering: 1933 chevy coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2014, 04:08 PM
Hello I am new to the forum. I am considering buying a hotrod that has a mustang II rack and pinion front end . I have just heard of EPS.I wonder can I buy an electric power steering unit that would fit and make it easier to steer in my soft Georgia dirt drive and parking space. Or is that just for newer cars ?
Thanks to anyone who can answer this
Phil
Old 07-01-2014, 04:33 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you have manual the conversion to power is not all that hard..Just need the pump and hoses and the correct steering rack.. Electric Power Steer has not as yet been adapted to our hotrods..
Sam
Old 07-01-2014, 04:42 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Not exactly true:
https://www.unisteer.com/electric-po...-steering.html
Old 07-01-2014, 04:54 PM
Thanks to you both for your replys i have just paid a visit to inisteer performance products. Sounds good to me.
Old 07-01-2014, 06:02 PM
Joe G's Avatar
At work we built a '39 Ford sedan for a customer and used the Unisteer electric steering due to limited room in the engine bay for traditional power steering. It takes up quite a bit of space under the dash, but other than that we have no complaints.
Old 07-01-2014, 07:21 PM
Wiki Edits: 3
There is something new under the sun..
Sam
Old 07-02-2014, 09:08 AM
Electric power steering for $100 here's the link
The Following User Says Thank You to aisr For This Useful Post:
OneMoreTime (07-02-2014)
Old 07-02-2014, 12:14 PM
Wiki Edits: 3
Thanks.... Since I am a guy that needs inexpensive I will look into the EPS from that link as it will save me a bunch in fabrication time...
Sam
Old 07-02-2014, 12:29 PM
ogre's Avatar
the 'Duracell Project'
that looks way too easy. i suspect a lot of classics will so have eps
Old 07-04-2014, 10:29 AM
Thanks Joe The Photo Helped .
Old 07-06-2014, 06:58 PM
Hi Joe , Your not any where near Atlanta are you ? I need some one to install EPS for me. Maybe you know someone near Atlanta that does ?
Old 07-07-2014, 04:20 PM
Joe G's Avatar
Sorry, I'm way up here in St. Paul, Minnesota. I'm sure there are capable shops in the Atlanta area, but I don't know anyone to recommend.
You might contact Unisteer and see if they have any dealer/installers in that area.
Good luck...
The Following User Says Thank You to Joe G For This Useful Post:
phil wilburn (07-08-2014)
Old 07-08-2014, 08:01 AM
Eps
Good Idea Joe Thanks , I do That .
Phil W.
Old 05-27-2015, 01:10 PM
Sam
Sam I have given up on electric power steering . (not enough room for me .) Now I am back on the idea of traditional PS.
I mentioned in passing my desire for power steering to a mechanic acquaintance of mine . He said there would be a lot of cutting and welding to be done along with the belts pump and setup about a thousand dollars . Your opinion please . thanks
Old 05-27-2015, 04:35 PM
Wiki Edits: 3
Since you have the MII rack now you may be able to change it out for a power rack. Check with Speedway and take the end to end measurement to make sure the new rack bolts in. Also check the measurements on the mounting bolts. On the engine assuming you have an sbc you will need a pump which ca be sourced from a wrecking yard and the hoses. you will need a restrictor to allow the proper pressure from the sbc pump to the ford rack.
Depending on your skill level this can be weekend bolt on project. I have no clue as to what may be needed on you particular rig as to welding a fabrication..
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
phil wilburn (05-27-2015)
Replacing a manual steering rack with a power rack on my 1933 chevy dmans Suspension - Brakes - Steering 2 12-05-2014 01:11 PM
Intro: 1933 Chevy coupe john56h Introduce Yourself 11 03-11-2008 06:08 PM
1933 chev 3 window coupe Knightrider Body - Exterior 1 01-30-2003 07:12 PM
