Electric Power Steering Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2018, 03:42 PM
I have a 1956 Studebaker Hawk resto-mod that has a Chevy 350 crate motor with AC. The style motor mounts used to clear the low hood, along with the AC compressor, prevent using a motor mounted mechanical power steering pump. I have been reading about electric hydraulic pumps at other forums using 2000-2005 Toyota MR2 Spider PS pumps (they have the reservoir and pump as one unit) with guys having great success. However, between the racing guys and people converting their gas cars to electric, prices for these used pumps are averaging $400 at salvage yards and on eBay with new ones at Toyota just shy of $1000! I found one hot-rodder online who used a Mini Cooper electric power steering pump but the wiring was not straightforward as the MR2. Does anyone know of another source for electric hydraulic steering pumps that wire up even somewhat straight forward and don’t require a second mortgage?
Thanks!
Old 06-20-2018, 04:17 PM
Old(s) Fart
Last wiki edit: Wheelbase database
Get rid of the hydraulics and just run electric power steering directly. Much less to worry about.
Old 06-20-2018, 10:17 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Do a search on EPS electric power steering..
Sam
Old 06-21-2018, 07:28 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
eps
several pages of info
ww.hotrodders.com/forum/35-electric-steering-fail-safe-no-ebay-module-needed-pics-454530.html
it didn't do a link so copy paste and search
Old 06-21-2018, 08:43 PM
Mount the power steering pump on your inner fender. Mount a electric motor directly to your pulley. Need to make a sleeve and flange for the shaft to slide into. Then make a bracket so the electric motor is mounted right to the pump bracket.
https://www.summitracing.com/parts/m...stionsanswers/
Spins 2900 without load and around 2000 under load.
Retain stock lines, stock pump, 2 wire setup with a relay or two. Easy to mount and no need to mess around touching your steering column. Keeps a steady rpm so you can idle into that parking spot. Simple.
More fun things with this;
Have the ablity to have it shut off above X speed via gps switch or just run it on a switch to kill it manually or just let the thing run key on to key off. Don't want it on the inner fender. You run long enough lines and can mount the thing in many different spots.
Something I always think of when buying "kits" is if this thing dies where can I get parts. Been burned many times when parts disappear due to company going out or the big manufacture refusing to stock parts for a older model.
The electric motor listed can be to your door within 3 days and if your using a stock pump and lines that is a trip to the parts store or 3 days to your door.
Bam electric steering(conversion) for under $200. Under $100 if you have the stuff to make the brackets around the shop.
The Following User Says Thank You to cerial For This Useful Post:
Stude Nut (06-23-2018)
Old 06-22-2018, 01:02 AM
This was covered a while back on this link: https://www.hotrodders.com/forum/35-e...cs-454530.html
Electric drive for power steering pump cerial Suspension - Brakes - Steering 8 01-20-2016 03:39 AM
BBC with electric water pump AND power steering MalibuMike Engine 9 11-20-2013 11:51 PM
Electric power steering pump fullthrottle777 Suspension - Brakes - Steering 4 01-01-2013 01:45 PM
Electric power steering jearsley Suspension - Brakes - Steering 1 12-08-2010 12:29 PM
power steering pump as a secondary oil pump? lowROLLERchevy Engine 17 06-04-2007 04:02 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
