"electric vacuum pump for the brake booster" - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-27-2009, 06:35 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Originally Posted by Bluejackets67
Most boosters need 15 to 18 inches of vacuum. On a 57, part of your problem may also be a 7" single diaphragm booster. If you have the room, I'd use a 9" single diaphragm or at least a 7" dual diaphragm booster.
Stainless Steel Brakes Corp. also has an electric vacuum pump.
If you are going to make statements representing facts at least get the fact correct 20 " is the industries suggested standard @ idle..
joeDa here is all you need to know about boosters: http://www.mpbrakes.com/technical-su...r-boosters.cfm
forget all the guesses here, go with what is known
  #17 (permalink)
Old 01-27-2009, 01:04 PM
This is directly from the website that you posted:
How much vacuum is needed to operate a booster properly?
For a power booster to function properly you will need at least 18" of vacuum at idle in park. Anything lower will give you a hard pedal.
I have personally seen (with the vacuum gauge) a vehicle that have had as little as 15" and still work very acceptable.
  #18 (permalink)
Old 01-27-2009, 06:37 PM
Gast makes a 12vdc vacuum pump for ambulances. It's very reliable and quiet. I think it runs about $150. Thomas also makes a good one but it may be pretty pricey. A google search will probably find some industrial suppliers that sell them.
The early 80's GM pump is pretty rare and expensive when found. Think it was in GM's early 80's 2.2L (Cavaliers?).
  #19 (permalink)
Old 01-28-2009, 06:55 AM
pepi's Avatar
good one, the price sounds right and the fact that it is quiet is another plus, that was the one thing about these pumps that was a turn off , noisy, but for me I needed the vac and after the car is fired the exhaust is so loud if covers it ... however I am going to look into this product I am sure the noise is a consideration when it comes to ambulances thank again for the input....
looks like :
Miniature Diaphragm
10D1125 Series is the ticket here
http://www.idex-hs.com/support/gast/...urecatalog.pdf
  #20 (permalink)
Old 01-28-2009, 09:13 AM
Summit has several pump kits listed in their catalog.
We are installing one in a 1966 Impala that we installed one of the new 427 crate engines in. That 427 crate motor is fairly radical and doesn't make enough vacuum at low speeds.........the thing goes like jet-stink but it takes both feet to even slow it down!!
We should have it installed by the end of the week so I will post the result.
Port or Full time vacuum cool rockin daddy Engine 126 10-05-2010 03:00 PM
vacuum gauge readings GMR Engine 11 08-25-2008 12:03 PM
Strange vacuum problem JohnyR17 Engine 7 03-16-2006 04:05 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
Brake Vacuum Boost billyg Suspension - Brakes - Steering 0 12-10-2002 08:21 AM
