Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Hoist to Engine Stand
Old 10-04-2019, 07:13 AM
timothale timothale is offline
Last wiki edit: General Motors transmissions
Wiki Edits: 27
spacer blocks
put some spacer blocks on your engine stand so the engine stand can ride over the hoist legs . when you slide them
face to face you will have a little bit of offset but you should be able to make it work. one of my engine stands I built has large castors and will roll on hard packed dirt when there is not enough space in the shop.
