Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Hoist to Engine Stand
Old 10-21-2019, 02:35 AM
cerial cerial is online now
I made it. You can buy similar things. But I really was not impressed with most of those designs.
If your garage has a strong enough beam a chain hoist makes putting engines on engine stands much easier.
I have set engine stand legs like the ones linked below on top of a engine stand cart linked below.
https://www.jegs.com/i/Speedmaster/7...iABEgLsM_D_BwE
https://www.harborfreight.com/500-lb...art-61405.html
This does work to adjust the height of a engine easy and get the thing onto a stand with most legs. But it is a smaller engine thing as your talking about 500lbs so you could potentially tip the engine.
They do make a 1000lb one. But I have no experience with it. Measure your spacing on your legs to make sure it will work. But it could be an option.
