engine rattle - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2003, 12:57 PM
Post engine rattle
Today I was driving for a while and when I got home I heard the scariest noise from under my hood hood. I turned the car off and heard the engine rattle as if it were falling out of the car. I checked under the hood to make sure none of the mounts were broken and they seemed fine.
Old 01-23-2003, 04:12 PM
Post
maybe your exhaust came loose or something, pop the hood and look!
Old 01-24-2003, 03:47 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves
Wiki Edits: 2
Post
Sounds like engine run on. Bad gas would cause this or timing.
Luv the smell of NITRO in the morning.
Old 01-24-2003, 04:02 PM
dmorris1200's Avatar
doesn't play well with others
Post
Sounds like run-on to me too. As stated, could be low octane gas, engine running lean (high combustion temps), ign. timing. Probably just a bad tank of gas if it just happened out of the blue.
BUILT FORD TOUGH
Old 01-24-2003, 04:08 PM
5.0Towncar's Avatar
Post
Where do you get your gas at? Hopefully not a 7-11. Those guys who haul that gas take a detour by their house and dump about a 100 gallons into some tanks and fill their tanker up with some water.I know for a fact that some of the people who haul gas do that,especially 7-11. Try Texico or Shell. Oh and by the way watch the tankers that pull in. It seems funny to me that there is only one kind of octane that they haul but they put the gas in different tanks that are supposed to be a higher octane. Steve
Old 01-24-2003, 04:50 PM
Post
Steve, been in the gas business for years with 2 major oil companies and independent trucking companies, I've never heard of anyone putting water in tankers. 7-11 gas in this area comes from a pipeline based in Oklahoma City. Fast idle can also cause run on.
Old 01-24-2003, 05:13 PM
Post
Don't mind Steve, he was obviously a big X-Files fan.
BUILT FORD TOUGH
Old 01-25-2003, 05:08 AM
5.0Towncar's Avatar
Post
I'm not ****'n you. My wifes dad was a truck driver for years and he knew that people did that :p . *** probes call me a liar. I'm not a ****ing HRK. Steve
Old 01-25-2003, 05:15 AM
Post
Steve, must you act like a five year old. The only people on this board that their posts constantly look like this *** ***** ** **** * are you, the puppy, and sometimes Neil. Is your vocabulary that limited that you can't just write without every other word being edited out or do you just think that we're going to read all your edits and go 'wow he's tough man, better not mess with him'? Are they like your security blanket?
BUILT FORD TOUGH
Old 01-25-2003, 05:41 AM
Post
Steve, not calling anyone anything. I've gotten my share of free gas from trucks, really loved it when friends hauled av. gas. Also tried ethanol, couldn't use too much though.
Old 01-25-2003, 11:56 AM
5.0Towncar's Avatar
Post
I really could care less if anyone does or doesn't believe me. It's not like I know anyone on here personally. Steve
[ January 25, 2003: Message edited by: 5.0Towncar ]</p>
Old 01-25-2003, 05:35 PM
1BAD80's Avatar
Wiki Edits: 2
Post
Just to let you know there have been some tankers caught thru the years by the police here in Mich. for diluting the gas with water and other types of junk.
Old 01-26-2003, 01:13 AM
Post
I'm sorry but you can't just mix gasoline and water together! They don't mix without adding another ingredient such as alcohol that will interact with both water and gasoline! You can see this by simply letting a little rain get in your lawnmowers fuel tank! The water will set on top and if you have enough fuel the lawnmower will run until it starts sucking water. Common sense will tell you that if stations were trying this, some people would end up getting full tanks of water!
Old 01-26-2003, 04:34 AM
5.0Towncar's Avatar
Post
They don't care they just want the stores think they got they full amount they ordered. Steve
Old 01-26-2003, 05:12 AM
banned
Post
OKay can I give my two sense... I used to work at a gas station not like it matters cuz this is more of a common sense thing... Anyhow the tanks are drained from the bottom (they have to otherwise they would be sucken and getting air and the tanks would still have gas in em)... Water sits on top of gas... Now when I worked at shell snow and rain and such would get into the tanks when we did dips.. It doesn't matter though cuz it just sits on top and since the gas drains from the bottom and the level never gets low enough for the tanks to get that dry you will always have pure gas being put into your vehical.. Unless there is a tremendous amount of water in there but the gas station workers can tell when they do dips because you are supposed to use a water paste to check how much water is in there when you do dips (not like we ever did but then again my boss was a jerk and didn't care about customers or employees) So yeah.. the chances of there being any significant amount of water coming out of the pumps into your gas tank is very low..
