Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Engine Swap Question
Old 05-20-2019, 03:56 AM
Hipster_G Hipster_G is offline
There a little more to it then just a thin plate adapter as the ring gear is on the converter on a mopar and the starter bolts to the mopar trans bellhousing. I know several that used this kit to put a 200r4 behind a big block and let's just say the adapter doesn't support the starter as well as the bellhousing and with the chevy trans there is no support for the nosecone of the starter.
Wilcap Store
I would source a Chevy engine in this case and bolt it in. Cheaper then adapters or bellhousings or custom built converters/flexplates.
