Exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2019, 02:54 PM
Exhaust
How far can I safely have my exhaust (headers) to my fiberglass firewall before I have to add a heat shield?
Old 05-16-2019, 06:25 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Personally, I would use thermal pad on the firewall if a pipe was within 3" of the firewall.
https://www.summitracing.com/parts/h...hoCxkEQAvD_BwE
Or, you might want to just wrap the pipes with thermal barrier.....
https://www.summitracing.com/parts/dei-010127
Old 05-16-2019, 06:58 PM
Don't do wraps or sticky stuff.
Do shields.
They go on easy with ties knocking down heat effectively.
The best thing is that they also come off easy/replace if you have something unexpected happen.
https://www.heatshieldproducts.com/h...ld-armor?amp=1
Old 05-16-2019, 07:25 PM
Heat shields
Thanks for the replies. The closest pipe will probably be about 4-5 inches from my firewall. What is the opinion on a metal heat shield?
Old 05-16-2019, 09:35 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Metal heat shields can work well mount them so there is at least a half inch gap between the exhaust pipe and the heat shield.. You see them on some T's and motorcycles to prevent burns to the passengers.
Sam
Old 05-16-2019, 10:56 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Think you will be fine, with those numbers. Unless they a cherry red from the ex port out to the first bend.
I guess the real question here is, two fold. What kind of car and how much whoop a s s, is it sporting?
Metal heat shields, never ran any, but on bikes always dug the sound when they are cooling down.
Pep
Old 05-17-2019, 07:20 AM
55 Tony's Avatar
4-5" I wouldn't worry about unless it's adding unwanted heat to the interior of the car, then a heat shield not a wrap.
Young enough to learn ... too old to remember.
Old 05-17-2019, 07:24 AM
Sam
Thanks Sam. So, you say at least a 1/2" between pipe and shield, correct? With that in mind then, there should be no problem with the shield 4" away from firewall? Tom
Old 05-17-2019, 07:26 AM
Thanks. This is a roadster, so there would not be a "hot inside car" issue. I just don't want to burn the firewall.
Old 05-17-2019, 07:28 AM
Pep
It is only three hundred horse
Old 05-17-2019, 07:45 AM
silver74vette's Avatar
The heat shield will be much cooler than the exhaust pipe. As long as you have about 3 inches of clearance you should be good. Take a look at the exhaust system on a Porsche 911. Just swapped one on a 2003 and the heat shields around the mufflers (right outboard of the heads) were about 2 inches from the bumper cover (plastic).
Old 05-17-2019, 12:09 PM
Having a few fiberglass builds under my wrenches 4 to 5 inch gap is plenty. If needed heat shields either attached to the exhaust or to structure are very effective, it takes remarkably little clearance to the heat source.
I'm not a real big fan of header wraps, while effective they really run the temps on the pipes up to where if you're not using a high quality header you can expect a dramatic reduction in their life span.
Bogie
Exhaust Tip Question daveh Body - Exterior 6 01-28-2018 08:07 PM
extreme FI comp cams CJ_1080 Engine 6 06-23-2011 01:03 PM
longer exhaust duration ? 383silverado Engine 5 05-23-2007 07:24 AM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
Exhaust formulas vs. computer programs Mean Dean Introduce Yourself 1 07-13-2004 12:26 PM
