Exhaust Tip Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2018, 02:49 PM
daveh's Avatar
Hey guys,
Not sure where to post this but the exhaust is on the exterior. Anyway I'm installing my exhaust on the Challenger and my exhaust tip is the same diameter and the exhaust pipe. It is chromed stainless.
1. Will the stainless tip expand without cracking so I can put it over the exhaust pipe? That was the way they were from stock. Like I said they are the same diameter so it doesn't need much.
2. Should I just expand the exhaust pipe and put the tip in the exhaust pipe and band clamp it?
Thanks Dave
Old 01-24-2018, 04:15 PM
delawarebill's Avatar
exh tips
if it don't need much and i mean very little.. i'd try a propane torch and heat the inside of the tips and see if u can slide on or light tap. it also might help if u took at rag soaked in water and froze it to rape around the exh pipe to shrink while heating the chromed tip..
Old 01-24-2018, 07:10 PM
Cars, Trucks, Boats
Is it chromed stainless or just polished stainless? IF chromed, the chrome is likely to crack... The stainless may be really strong and difficult to expand... butt welding might be better...
t
Old 01-25-2018, 01:03 AM
You can get exhaust adapter stubs at O'Reilly or Autozone with an O.D. the same as your tips I.D. for next to nothing and slip it together.
Old 01-25-2018, 07:21 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Get an some exhaust pipe that fits the INSIDE diameter, and sleeve it, a 3 -4 inch section should do it, or whatever you think works for you.
Shove half of it in the tailpipe and the other in the tip, it will hold and align things up.
Can use band clamps, make sure the bolts face UP, cleans the look of the install looking from the ground. if that matters.
Greg
Old 01-28-2018, 04:59 PM
I would buy an adapter rather than trying to expand it. The chrome will crack and won't look good.
Old 01-28-2018, 09:07 PM
rip-tide's Avatar
Adapters you speak of are for two different sized pipe. The problem is two pipes of same OD & ID to be joined.
One of two ways to solve the problem
Have a pipe that the ID fits over the OD, of the tailpipe and tip. Slip the tailpipe & tip into that pipe. That would require two butt ugly muffler clamps.
Or have a pipe that the OD fits in the ID, of the tailpipe and tip. Slip that pipe inside of the tailpipe & tip, clamp with 1 band clamp... much cleaner
Exhaust question trblmker Engine 11 05-11-2012 08:12 AM
exhaust question pjc360 Engine 16 05-06-2012 08:51 AM
roller tip to valve tip alighnment eliot Engine 5 07-31-2007 01:33 PM
Polished up my exhaust tip Malibucdl Garage - Tools 2 03-14-2006 11:56 AM
Chipped exhaust push rod tip jpd37 Engine 4 02-21-2003 02:03 PM
