Exterior heat insulation?... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2018, 04:40 AM
In my 1981 Citroen CX, the exhaust muffler is right under the center console, and it heats up the interior pretty badly. I certainly do not want to remove the center console, it would be too much hassle (the heater box is in it, the heater control cables are between the 2 seats...), so I cannot install interior insulation.
So what can I use to insulate from the outside? That insulation would obviously be exposed to the weather, road dirt, maybe some grease/oil... The underbelly has the factory tar coating/rust protection, in very good condition still. And there is no real space to mount the muffler elsewhere either.
Thanks!
Old 12-16-2018, 06:40 AM
Bob37pont's Avatar
Curmudgeon at Large
Perhaps you could use header wrap to cover the muffler & pipe in that area.
Old 12-16-2018, 08:56 AM
Some products to consider:
https://www.google.com/search?client...60.K4Q0ppPJdLs
Old 12-16-2018, 11:01 AM
Thanks for these ideas.
I do not want to use header wrap because it tends to keep moisture in, and make the exhaust piece rust even faster. Same goes for something like a blanket kind of thing...
Crdnblu, I had kind of thought about a heat shield and would have never thought Amazon would have that! I will have to look into making one myself...
Old 12-16-2018, 12:05 PM
FlowMaster makes these in multiple sizes that might work for you, if you have the space, as they "stand-off" from the muffler:
https://www.amazon.com/s/?ie=UTF8&ke...l_48burv3rh2_e
The Following User Says Thank You to crdnblu For This Useful Post:
wave1957 (12-17-2018)
heat and sound insulation rxlmod Interior 1 04-22-2010 08:17 PM
Sound/Heat insulation material 67Mustang Al. Interior 2 12-05-2009 08:41 PM
i cant find the thread, plug boot heat insulation spinn Engine 6 04-13-2005 03:00 PM
insulation for heat and noise? Pharmy Interior 3 07-30-2003 11:39 PM
Heat barrier insulation Madd Syntst Interior 4 09-24-2002 09:43 AM
