fabing new suspension 57 dodge coronet - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2015, 07:41 PM
Last journal entry: Body work
I want to eliminate the torsion bar suspension on my 57 coronet project. I want to lower the car and make more room for accessories mounted low on the motor, AC, PS and Alternator so the original cross member has to go. I also want rack and pinion steering and sway bar. Has anyone seen this done on an early c body mopar? I can fabricate the A arms and cross member but need 2" drop spindles to start. I'm not sure how much weight forged mustang ii spindles can support. They are relatively inexpensive and have a bunch of brake options. I'm removing the poly motor and building a 392 hemi so it will be front heavy. Building a bit of a rat rod, as I'm not doing anything to the body but want it to ride, stop and handle well.
Thanks guys.
ID:	234641   Click image for larger version
Old 07-22-2015, 11:54 AM
S10xGN's Avatar
Gotta love a turbo!
If you're gonna fab the a-arms, why not use a G body GM spindle? You can get 2" drop versions for < $200 pair. Or look around on Speedway Motor's site at their stock car stuff...
Russ
Old 07-22-2015, 01:57 PM
raidmagic's Avatar
Last journal entry: Studebaker
How about pics of your current suspension set up and crossmember?
Old 07-23-2015, 06:54 PM
I don't really care which spindles I use but I want to retain the 4 1/2" wheel bolt circle. If I use gm spindles I would have to re-drill the rotors. I could post some pictures of the original suspension but it is all coming out. I don't want to use any of the original hardware. When I get the front sheet metal off I'll post some pics.
Thanks for the replies.
Old 07-23-2015, 07:00 PM
JeffB's Avatar
Since your project is a large car you might think about using a Crown Victoria front clip which uses the same bolt pattern wheels as yours,see if this video gives you some ideas: https://www.youtube.com/watch?v=zmrDRZwVS4A
1951 dodge coronet HemmiGremmie Hotrodding Basics 1 07-20-2015 12:48 AM
58 Dodge Coronet width? chicknsuit Hotrodding Basics 1 07-30-2011 04:52 PM
Dodge Coronet 318Poly Introduce Yourself 4 11-09-2010 09:25 AM
1969 Dodge Coronet R/T Duanekorbel Introduce Yourself 1 04-04-2007 06:09 PM
Singleton's 66 dodge coronet Singleton's Coronet Introduce Yourself 2 10-30-2005 03:44 PM
