Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fan clutch removal... no 'big nut' visible...
Old 12-03-2014, 10:12 PM
Silver Surfer's Avatar
Silver Surfer Silver Surfer is offline
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Use a long screw driver and wedge it in between the nuts and clutch shaft (red circle) being careful not to mangle the threads. Then use a box wrench to remove the nuts (red circle). Then the entire assembly comes off. Then use a wrench to remove the fan from the clutch (blue line).
The Following User Says Thank You to Silver Surfer For This Useful Post:
AutoGear (12-05-2014)
