Fasten fuel fill neck on fuel cell?
Probably a stupid question, but here it goes:
How do I fasten a fill neck, fuel level sender etc. on a fuel cell? I mean, the flange has obviously larger diameter than the hole itself, of course. In order to get the inside flange through the hole, I guess that flange is splitted in two? But the the problem remains that making the splitted flange stay in place while placing the fill neck on the outside and fasten a couple of the bolts? What makes the inside flange not falling down to the bottom of the cell? Is this operation done with the cell upside-down? Or do I use glue or something to keep the inside flange in place long enough to fasten a couple of the bolts? Or have I completley missed a point or two here...?
Sponsored Links | |||
It does come with a split flange with the bolt's made into it.. Once you put it into place, The bolts usually hold it up until you put the nuts on.. I did a couple and that's what I did.. You just have to be careful not to push it in.. Are you can turn the tank upside down to get them started... ![]() |
Recent General Rodding Tech posts with photos |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Questions about wiring a custom aluminum fuel cell | jhilb | Electrical | 1 | 11-01-2008 06:57 PM |
I need help with my fuel cell cap | 70Velle350 | General Rodding Tech | 11 | 05-26-2008 09:06 AM |
aluminum fuel cell help | tomthecomic | Engine | 1 | 03-11-2008 04:53 AM |
Fuel cell fillers? | Crazy-J | General Rodding Tech | 1 | 11-12-2004 10:45 PM |
