faulty fuel pump 2000 mustang 6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2016, 01:42 PM
My mechanic says my fuel pump is not working and has to be replaced. Is there some other feature in the fuel system causing my engine not to start such as a faulty eec? I don't wish to spend a lot of money of course
Old 10-30-2016, 03:57 PM
Tim C's Avatar
If you do it yourself, or have it done for you, make sure to replace the fuel filler neck grommet. They're notorious for splitting and leaking on 79-2004 mustangs. The grommet can be picked up from any parts store or the Ford dealer.
Sent from my XT1254 using Tapatalk
Old 10-30-2016, 08:35 PM
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
i have to look at the wiring diagram... but you should probably check for voltage while cranking at the inertia switch .. so you can see if the fuel pump relay or the CCRM is actually supplying turn on voltage to the Fuel pump driver module..
learn these guys.. most returnless ford fuel system are wired in a similar manner. some have CCRMs. some have Fuel pump relays to supply power to the inertia switch.
one can test the fuel pump directly by disconnecting the fuel pump driver module that is probably in the side of the trunk..
using a jump start box to supply power to the fuel pump wiring directly..
the Red and black stripe gets positive power
the Brown and pink stripe gets negative power.. this will make the fuel pump run..
there is always the rubber hammer method.. while somebody cranks the engine.. another person under the side of the car pounding hard with a rubber mallot on the bottom of the fuel pump.. this will usually get your failing fuel pump running one more time at least..
i had one caravan that had a totally full tank.. there was no way to drain the gas so i used a remote starter button and a rubber hammer to pump the gas out of the tank.. only took me an hour. but its better than a huge gas spill all over..
Fuel Pump 1993 Mustang H137 Engine 1 12-03-2010 06:30 PM
Fuel Pump 1993 Mustang H137 General Rodding Tech 1 12-03-2010 05:54 PM
2000 Jimmy fuel pump relay donna cook Electrical 3 02-02-2009 05:59 PM
Question on 2000 Cadillac fuel pump garretthes Engine 0 10-13-2007 12:39 AM
88 Mustang Gt Fuel Pump Help 406 ss monte Engine 5 01-13-2004 01:58 PM
