fiberglass to metal or epoxy?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2008, 06:21 AM
71corvette's Avatar
I am customizing my stock metal running boards on my 50 chevy truck. I installed wider fenders and need to flare them at the rear to meet the wider fender. I will do the mods with metal but want to smooth out the grooves in the top of the board with fiberglas mat or cloth. after I blast them should I go ahead and epoxy prime them or would the glass get a better bond to bare metal? epoxy wold give corosion protection.
Old 11-18-2008, 07:22 AM
Last journal entry: More painting pics
Polyester resin will stick well enough to metal for cosmetic purposes if done properly. Surfaces should be very coarsely sanded and very clean. I have heard that it sticks better to epoxy primer but have never tried it myself and would advise you contact the manufacturers of the primer before trying it.
If in doubt or if the work will be taking strain of people stepping on the running boards you could use epoxy resin for your fiberglass work in which case you do not need a primer. (If you use epoxy resin you cannot use regular fiberglass mat.)
Old 11-18-2008, 01:53 PM
i have used kitty hair (a fiberglass reinforced filler) straight on to metal. The car sat outside at plus 100 and down to minus 25, kit a wall at 60mph and the filler did not loosen or degrade in any way. I was taught straight to metal but I have also seen a sealer/primer used first.
Old 11-18-2008, 04:59 PM
boatbob2
running boards.....
HI,why not cut a piece of 18 or 20 guage metal,to fit,then plug weld it over the old running board???BUT,prime both pieces of metal BEFORE welding.
Old 11-18-2008, 05:12 PM
71corvette's Avatar
thanks, I actually talked to Barry from SPI today and he recomended the same thing, but on top of the epoxy primer. so I will make the mods with the metal and do the finishing work with kitty hair
Bonding injection molded fiberglass to metal A/G WILLYS Body - Exterior 2 09-28-2008 01:27 AM
Metal prep prior to epoxy Dan O. Body - Exterior 1 05-17-2008 03:46 AM
Permatex epoxy (all metal) gas tank. 1Fast65Elky Hotrodders' Lounge 8 10-03-2006 02:00 PM
making a fiberglass replica of a metal hood. Dubz Body - Exterior 1 06-28-2005 05:10 AM
Good epoxy primer? Since New PPG dplv stinks on bare metal? zachscc Body - Exterior 3 11-15-2003 10:25 PM
