Fiberglass paint stripper and paint - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 12-12-2018, 05:32 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I'm stripping a snowmobile cowling that the PO used rattle can clear on, it's a mess. Hand sanding clogs the paper in a big way.
Is there a paint stripper that is fiberglass friendly? I used heavy duty strippers on my Nova and wouldn't dare put it on thin fiberglass.
I was told to use CitriStrip, but it says on the label not to use on fiberglass. I put it on a small section, let is sit for half an hour, it didn't even start to remove paint.
What are my options other than elbow grease?
I may use a rattle can paint, is Krylon Fusion about the best for my application?
Semper Fi
Old 12-12-2018, 08:25 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
If its rattle can clear, try lacquer thinner to wipe that off. Test small area first. I've only used DC rattle can, not impressed by it. If you want a better looking longer lasting shine, I hear catalyzed "2K" aerosols are a realistic thing now. Cost more but not like bodyshop paint because you don't get much.
The Following User Says Thank You to idrivejunk For This Useful Post:
68NovaSS (12-13-2018)
Old 08-17-2019, 11:14 AM
Pats55's Avatar
Kleen Strip makes a fiberglass paint remover. They also make aircraft stripper DO NOT use the aircraft stripper on fiberglass Eklers corvette probably has it
Old 08-18-2019, 12:25 AM
I do not trust the chemical fiberglass strippers, others may have had luck with them, I haven't. Most fiberglass layups are not perfect and the chemicals can creep into porosity/dry lay-up and cause problems.
If it's spay bomb the lacquer thinner suggested should take it off.
I normally da with 80g until I'm close to the original gel coat and finish out with 180g then re-gel coat or polyester primer. No goofy chemicals on glass for me. They can make one hella mess of things.
optimal temperature for naval jelly and paint stripper onebadmerc Body - Exterior 4 03-07-2008 01:41 PM
whats the best paint stripper? badknuckles Body - Exterior 3 03-03-2004 12:07 AM
paint stripper robbysapien Body - Exterior 3 10-13-2003 12:33 PM
paint stripper KNIGHT07731 Body - Exterior 2 08-13-2003 07:47 AM
Best Paint Stripper Slickriffs Body - Exterior 7 08-11-2003 07:54 AM
