filler to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2018, 01:37 PM
filler to use
Going to bolt and then weld rear fenders onto 48 Pontiac. After welding I will need to use some filler to smooth this seam in. I'm concerned about any flexing in the fenders that might cause cracking of the filler.
considering using Evercoat , either Fiber Tech or Metal 2 Metal.
Any thoughts pro or cons to either method ? Thanks Jeff
Old 12-29-2018, 10:00 PM
put up or shut up
Use metal to metal around the seams but clean up the metal really well. Wouldn't hurt to add some hidden bracing to keep it more stout.
The Following User Says Thank You to tech69 For This Useful Post:
Jernsberger (12-30-2018)
Filler over epoxy or Epoxy over filler? Here is some good info satexasf150 Body - Exterior 78 10-16-2011 09:35 AM
What kind of filler to use on urethane? segge Body - Exterior 1 05-09-2006 10:09 PM
What Filler Should I Use markl Body - Exterior 5 11-06-2005 01:18 PM
brand of body filler, primer, paint to use? montea Body - Exterior 10 03-26-2005 11:01 PM
Never use body filler on metal?????? daimon1054 Body - Exterior 10 04-05-2004 03:47 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
