Finding GM Pulleys - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2018, 04:12 PM
mjgord51's Avatar
Born 13th Generation U.S.A.
Finding GM Pulleys
The other day I was Googling and Searching for GM pulleys in particular different numbered pulleys and came across this Camaro Pulley Listing and thought if there is something like it for 67-72 Chevy C-10 Trucks.
I don't want to hurt some peoples feelings when I say most Hot Rods use the Chevrolet Engins so I thought this would be a good place to start looking to see if anybody knows of such a Book or Master Catalog floating around or info "Links" ?
thanks in advance
PS; Here's what I found two pages below
ID:	415545   Click image for larger version
Old 02-16-2019, 10:29 AM
mjgord51's Avatar
I am looking for all the pulleys (narrow grove) for a stock SBC engine with pow/strg only, no A/C at all. My truck is a 68 C10, 305ci (no jokes please) with the Alt on drivers side as it should. I do have two different pow/strg pumps (lines different from one another) with different set backs for the single pulleys on them. I have found two for the Harmonic Balancer but not sure if they are right for the fitment I want/need.
PS, probably should have said I am looking for "Original" pulleys, Don't like aftermarket, alum, chrome at all.
Old 02-16-2019, 11:39 AM
55 Tony's Avatar
Great to hear you aren't a chrome fanatic. Did you ever see the money people pay for the billet stuff? My factory gm pulleys work just fine, and I don't have to polish them either.
Young enough to learn ... too old to remember.
Old 02-16-2019, 11:48 AM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
A couple of pictures I found. Might help
You sure it's a 305 and not a 307?....The 307 was available in 68. the 305 not until 76
I wonder if common sense will ever make a comeback?
Old 02-16-2019, 12:56 PM
mjgord51's Avatar
Yes I am quite sure its a transplant 1989 305 with a 1992 4L60 (non "E") trans.
Should have said the stock casting numbers are what I'm looking for, easier to find them if having the right numbers.
I also have them two pics and a few more.
Thanks
Old 02-16-2019, 12:58 PM
mjgord51's Avatar
Tony, Do you happen to have some pics of your setup as well do you have the casting numbers of your pulleys?
PS, my truck did come with chrome pulleys, "yuck" lol
Old 02-16-2019, 05:36 PM
55 Tony's Avatar
I have a Big Block and have no idea of the numbers or if they are interchangeable. I can try to get a decent pic if you like.
You can sandblast the chrome and paint them a nice gloss or semi gloss black! Or buy black ones and sell the chrome.
Old 02-16-2019, 08:24 PM
mjgord51's Avatar
That's ok I am looking for small block pulleys, big block pulleys are different not interchangeable IIR.
Old 02-16-2019, 10:38 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
I'm going to guess you are aware that the pulleys depend on the water pump. Left hand alt requires a short pump and matching pulleys. I have this set up on my '67 Camaro and can see if I can read the pulley numbers tomorrow. They are all original GM.
All sbc thru 1968 had left hand alt with short pump and pulleys. 1969 was the change over year to long pump and right hand alt.
Old 04-28-2019, 06:45 PM
mjgord51's Avatar
I'm sorry TMP got side tracked for a while. Yes if you can get the pulley numbers would be great. Yes I have the alt on the drivers side and yes I have a short water pump along with this setup for the power steering pump below are pics of them.
Name:	Power Strg Pump Lower Mount Bracket 001.jpg
ID:	442785   Click image for larger version
Name:	Power Strg Pump Lower Mount Bracket 002.jpg
ID:	442787   Click image for larger version
Name:	Power Strg Pump Lower Mount Bracket 004.jpg
Old 05-07-2019, 06:28 AM
OK, I finally remembered to look at my pulleys in the shop.
The pulley on your ps pump appears to be correct...as long as it is stamped 3770509
My fan pulley is 3788472
engine add on pulley, 3751232
Old 06-20-2019, 11:09 AM
mjgord51's Avatar
Here is all what I have collected in pulleys so far. All pulleys are Stamped Steel with only one being Case Steel. Most are normal thin type but two are of heaver material.
The WP pulley without numbers (no #'s) came from a 6 cyl Chevelle motor which I was told it can be used for SBC motors.
The Heavy Duty WP three grove pulley the one with much more material steel stamped I believe would be used for a 350 or 400 SBC motors. This pulley I have read causes WP bearing failure.
Name:	My Pulleys I Have.jpg
Pulleys? USMC_Bravo Engine 6 03-06-2011 11:51 AM
Pulleys Zeater1 Engine 1 07-05-2005 09:31 PM
Pulleys Longboard Engine 6 03-25-2005 11:43 PM
pulleys jpspridd Engine 3 10-21-2003 06:12 PM
pulleys Camaro2Fast4u Engine 0 03-14-2003 06:50 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
