Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - AN Fitting to Aluminum Tube
Old 03-13-2019, 03:13 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
IMO its a matter of having the correct tools.... a lot of guys don't do enough AN line flaring to recover the expense of the 37 flaring tool.
Don't forget that the flared aluminum line also needs a tube sleeve to go along with that tube nut.
I have used the compression fitting type hard line to AN adapters several times without a problem. Compression fitting on one end and AN male on the other was the type I used....you can get them with AN female also.
I don't remember if they were Earls or Russell.
The Following User Says Thank You to ericnova72 For This Useful Post:
MoonBat (03-13-2019)
