AN Fitting to Aluminum Tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2019, 01:01 PM
I am running a fuel line from a trunk-mounted fuel cell. The fuel line is 3/8" OD annealed aluminum and the fitting at the fuel cell is AN-8. The tube manufacturer (Earl's) says the tube can be flared. I have ordered a AN-8 to AN-6 reducer to match the tube size
I am inclined to use a flared fitting rather than a compression fitting but I would appreciate input from more experienced rodders. Is one type superior or is it a matter of available tools ?
Thanks,
Buzz (MoonBat)
Old 03-13-2019, 03:13 PM
ericnova72's Avatar
More for Less Racer
IMO its a matter of having the correct tools.... a lot of guys don't do enough AN line flaring to recover the expense of the 37 flaring tool.
Don't forget that the flared aluminum line also needs a tube sleeve to go along with that tube nut.
I have used the compression fitting type hard line to AN adapters several times without a problem. Compression fitting on one end and AN male on the other was the type I used....you can get them with AN female also.
I don't remember if they were Earls or Russell.
The Following User Says Thank You to ericnova72 For This Useful Post:
MoonBat (03-13-2019)
Old 03-13-2019, 03:14 PM
dusterdude3404's Avatar
If you're using a low pressure pump for a carburator,the compression fitting will do just fine.if efi,i would flare it.
Sent from my LG-US601 using Tapatalk
The Following User Says Thank You to dusterdude3404 For This Useful Post:
Old 03-13-2019, 06:10 PM
So were looking at this:
https://www.jegs.com/i/Earl's/361/AT...xoCrjwQAvD_BwE
Which I hate and can see leaking with high pressure once any coating around that tube gives way or the aluminum does not get crushed perfectly by that sleeve.
Why not get rid of the tube completly with a bulk head fitting?
Drill out the tube and run a an-8 bulkhead fitting.
https://www.holley.com/products/plum...RoC1r0QAvD_BwE
Pull the sending unit/ pump cover. Run the pump to submersible fuel hose to an-6 male barb /an8 female(reducer below link) to an8 through connection(above link)(that is a 10 use a 8 of course) to an8 female to barb or female swivel for the rest.
https://www.holley.com/products/plum...s/AT9892086ERL
The Following 2 Users Say Thank You to cerial For This Useful Post:
MoonBat (03-13-2019), Richiehd (03-14-2019)
Old 03-28-2019, 01:59 AM
I decided to go with flare fittings. Got the tool today and made a couple flares for practice.
Part of this project is to have a fun ride when I'm done ('31 Model A roadster hot rod). The second is to learn new skills.
Thanks for the helpful posts.
Buzz (MoonBat)
Aluminum Radiator or Copper Liberty5601 Engine 6 10-08-2014 08:43 AM
How to clean aluminum with acid and baking soda 4 Jaw Chuck Engine 4 03-28-2014 11:57 AM
Bending Tube 62slantsix General Rodding Tech 19 06-03-2010 03:04 PM
aluminum tube for a 4bar set up? thintin Suspension - Brakes - Steering 1 05-13-2009 06:30 AM
Aluminum SBC Heads SierraClassic400sbc Engine 14 03-28-2009 03:53 PM
