Fixing basecoat for white pearl - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2017, 09:26 AM
Hey guys, I am a bit of an amateur paint "enthusiast" and enjoy painting but really have trouble getting consistent results. My car (painted with white pearl) had a rust spot I decided to touch up the other day and, aside from the tiny rock chip sized piece of rust revealing a massive rust cavern, had an issue with the basecoat. Primer went on well, wet sanded it with 400, nothing too exciting. Spray out test said 3 coats of white to match. Shot the base about 24 hours ago and it appears that it flashed way too fast, got some nibs, a run (got excited with edge blender) and some read through on the sanding marks. The gun is an LPH80 with 18 psi at the gun through a 1.0 tip with fast reducer. I'm thinking next to sand out the nibs and a bit into the base with 600, clean up the overspray up with 600 so everything is smooth, drop pressure to 12 psi and use a slower reducer.
I also have an Iwata LPH400 and W400 that I could use for this but with the size of the repair these guns seem like hunting mice with an elephant gun.
Also how do you guys clean up edge blender between coats? Are you usually able to spray right over it? If you have other tips or something different to try that might help, I'm all ears
ID:	387426   Click image for larger version
ID:	387442   Click image for larger version
ID:	387450   Click image for larger version
Old 11-12-2017, 09:31 AM
And just for the record the last picture was what I discovered (and then realized what I just got myself into) sanding into the rust spot, not what I primed over. Also the more yellow stuff was touch up paint i tried to apply with an airbrush. Didn't work, oh well, lesson learned.
Old 11-17-2017, 03:38 PM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
It all starts with the white pearl it was painted with. Is it the original paint that matches the paint code?
Pearl White really that hard to repair?? Dilbert Body - Exterior 4 05-05-2012 03:19 PM
Wanted: pics and or vid of any car that is painted white with a pearl, KCUF Body - Exterior 8 10-31-2007 12:19 PM
painting pearl white ricksautorestoration Body - Exterior 4 01-23-2006 07:24 PM
Pearl white paintjob swoodard23 Body - Exterior 4 08-14-2005 09:25 AM
Question about Snow white pearl from House of Kolor. Fordy8man Body - Exterior 6 03-20-2005 11:42 AM
