Floor Pan Paint Question - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 04-27-2016, 06:54 AM
daveh's Avatar
Hi Guys,
I just finished putting in some patch panels in the floor of my Challenger. After I finished the patches I stripped the entire floor and primed it. I'm sure this has been covered but I can't find exactly the answer I'm looking for.
I'm looking for a top coat that will really bite into the floor and protect it before I install the dynamat. I don't care for POR15 and since the floor is in overall good shape I just want to protect it from future issues. I'm actually thinking of the Rustoleum rattle can spray paint since you aren't going to see it or would the Rustoleum brush on paint be better?
Or is there something better that I can use that will stick well to the metal. Thanks in advance for your help.
Dave
Old 04-27-2016, 07:53 AM
PHWOARchild's Avatar
I did the floors of my '59 Ford with Duplicolor from Auto Zone. Anyone sells it I'm sure. Cost me around $27 a quart and sprayed on nicely. No rust on my floors, I just scraped up all the crud off it, wire brushed and washed it out first. I'm using Fat Mat over it.
Old 04-27-2016, 08:22 AM
delawarebill's Avatar
pan finish
how about rattle can bed liner spray.. it's kinda a thin coat and dries fast. i used it on the fairlane after power washing last yr to re-do my front susp..
Old 04-27-2016, 08:31 AM
daveh's Avatar
I like the spray on bed liner idea. Will the Dynamat stick well to that?
Old 04-27-2016, 08:41 AM
pans
i don't see why not.. its not teflon spray
Old 04-27-2016, 09:01 AM
daveh's Avatar
This stuff has good reviews. What do you all think?
Duplicolor Bed Armor, DIY Truck Bed Liner, Black, 128 oz. Gallon Kit BAK2010: Advance Auto Parts
Old 04-27-2016, 09:05 AM
paint
that should work well. i just used spray for the area i was coating.
Old 04-27-2016, 09:14 AM
daveh's Avatar
I'm going to be doing the entire floor and inside firewall so I think I need a gallon.
Old 04-27-2016, 09:43 AM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
Just paint it. The bed liner stuff is okay but, if you have to do ANY work on the floor, it creates a huge sticky mess. Any kind of paint will work. Brush on Rustoleum Industrial is very tuff stuff after it cures and it is easy to work with in the future.
Mark
Old 04-27-2016, 10:29 AM
33Willys77's Avatar
if its clean, epoxy primer (SPI)
Old 04-28-2016, 05:30 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
2 part epoxy primer like the pros use. It can be sprayed or brushed on. Do at least two coats it wont need any paint but can be painted if you want.
48 Chevy Cab Floor Pan Question andrewakessler Suspension - Brakes - Steering 2 09-25-2012 11:56 AM
brush on paint for new floor pan 66nova383 Body - Exterior 7 09-21-2011 05:58 PM
Floor Pan Bead Roll Question dirty dixon Body - Exterior 4 04-14-2011 02:06 PM
Question about new paint booth floor? FRANKBULLITT Body - Exterior 5 10-23-2007 12:03 PM
Floor pan question. Hippie Body - Exterior 0 04-20-2007 07:40 AM
