Ford 2.3L advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2009, 07:03 AM
Banned
Ford 2.3L advice
I'm looking for input on this 2.3L build for a Merc. Bobcat I just bought. here's what I have planned so far
2.3L block and crank, cleaned and machined as necessary
Esslinger 5.7" rods with KB flat top pistons
Lunati 32903 cam (227/227 @.050" .500" lift, 110 LSA)
Milled head for 11:1 compression
Ranger exhaust manifold
Acid ported ranger intake manifold
stock carb later switched to either a Holley 2bbl or a IR setup with large motorcycle carbs.
Head will be ported with matching valvesprings and larger intake valves (possibley exhaust too if I can find decent prices)
Does anyone know of a good place to buy larger valves for a decent price? I found $15 a pop, but that is about 3 times the cost of most other V8 valves.
Any tips or tricks would be greatly appreciated as this is my first Ford 2.3L
Old 06-24-2009, 07:24 AM
Wiki Edits: 31
you would use a 2.0 Ranger carb manifold? I don't think any Ranger 2.3's had carbs.. tho there the same basic engine design
my grandfather had 2 'cats' as he called them.. had the motors out of them numerous times for work and eventully the good bodied car's engine went, so he swapped the good motor from the rotted out 1 and junked it
Old 06-24-2009, 07:27 AM
Banned
I'm looking at a 2.3L from a ranger tonigh, the guy said its the single plug head type with a carb but it may not be carbed. It's $100 for the whole engine and I can use the short block for that price. the mid 90's ranger exhaust is the one I'll be running- they in a few salvage yards and they work nearly as good as a header.
Old 06-24-2009, 11:52 AM
Wiki Edits: 31
yup, I got that exh manifold on my '98 Ranger 2.5
single plug head is pre '89 IIRC, but I'm pretty sure it is EFI.. might not be a bad thing tho.. EFI would be better than a carb and you could tune the EEC-IV to work with the high comp or just use a MS-II
Old 06-24-2009, 02:18 PM
Banned
Do you thin the stock rods are good to 7000 RPM, or should I go with the Essy 5.7" combo. I don't mind spending a little money on good parts, but if they're not needed then I don't want to.
Old 06-24-2009, 03:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I think you shoul add a turbo like off a turbo coupe we did my sons ranger performed really well. JMO. Cole
Old 06-24-2009, 03:23 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Yeah, no kidding. That's what I had in mind in the first place. A bone stock 190 hp Turbo Coupe motor and 5-speed. YAHOOOO. Cheap and fast.
Old 06-25-2009, 06:30 AM
Banned
finding a turbo 2.3L is harder than finding a std. bore buick big block around here. As far as cheap goes- not even close. I would like to swap the entire drivetrain with a 5 speed, computer, and trans from a TC, but they just aren't around.
Old 06-25-2009, 07:38 AM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
There should be some around - and probably a lot cheaper then a stock build up. They started using them in Mustangs and Merc Capri's in '79. They really ran nice - as I had one with the TRX suspension. I sold it for a song with about 50K miles, but it needed a top skin - the moon roof caused major rust.
Irelands child
Old 06-25-2009, 09:02 AM
Banned
I found a guy tha's local taht is selling a NA 93 mustang 2.3L complete with wiring, accessories, and harness for $200. He called this morning and I may go with that one. I'll be doing a rebuild of it when I get it and swapping to forged flat top pistons, a cam swap (will probably go roller if I get this engine rather than convert it to use the flat follower cam I speced), and cleaning it up with new ebarings, gaskets, etc.
my next question is- I'm having trouble finding information on the 93 mustang computers. If I swap the injectors can I have a chip burned to run with a turbo or do I need to do more than that. I believe these engines are MAF, but I'm not sure and can't seem to find any solid info.
Old 06-25-2009, 12:59 PM
Wiki Edits: 31
it's EEC-IV and can be tuned for anything
46 ford p/u model # ( WRONG ) ? biglee550 Suspension - Brakes - Steering 19 03-17-2008 08:45 PM
Hey Ford Guys, HELP ID of Ford rear ?? 1939P7 Hotrodding Basics 10 07-18-2007 05:43 AM
T-5 transmission codes needed xntrik Transmission - Rearend 4 09-06-2005 09:09 PM
2.3L 88' ford ranger reliable? problums? Kenny13z3 Engine 10 05-21-2005 10:01 PM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 10:09 AM
