Ford 302 Heads: Is there a right and a left? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2019, 01:45 PM
I didn't take this engine apart so I don't know which head came off which bank. From what reading I've done it doesn't matter which head goes on which side except in the case of a bunch of emission control stuff? It is a '77 Ford 302 engine.
Can you really smart folks verify that it is ok that I may have put them back on the wrong side?
Thanks, --John--
Old 09-14-2019, 02:20 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Yeah, the only thing(s) that would make any difference would be things like water temp sensors and such and like you said, emission controls that would have to bolt to something else and might not fit if you got the heads switched. Otherwise, there is no difference in the operation of the motor.
The Following User Says Thank You to techinspector1 For This Useful Post:
46FordJohn (09-15-2019)
Old 09-14-2019, 02:24 PM
What Tech said.
Bogie
The Following 2 Users Say Thank You to BogiesAnnex1 For This Useful Post:
46FordJohn (09-15-2019), techinspector1 (09-14-2019)
Old 09-14-2019, 04:32 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
look at the accesory end of the heads. there will be bolt holes that are 5/8 thread and some that are 7/16 thread.
They are also part of the EGR passage.
If you get the heads on bacwards, you will need to get the thread inserts to bring them down to 7/16thread.
Now if you have non EGR heads, it may not have the larger holes.
Other than that, the heads are symetrycal
Original Smog Pump Threaded Insert 5/8"-11 To 7/16"-14 | Cylinder Head Hardware | Engine | Mustang | MustangsUnlimited.com
Fact is stranger than Fiction
Old 09-14-2019, 04:35 PM
LATECH's Avatar
Chances are, i your engine is a 77, they arent going to be present. Earlier ford engines used a plate under the carb for the EGR, so...
Just check them in case they are later model heads.
The Following User Says Thank You to LATECH For This Useful Post:
Old 09-15-2019, 02:33 AM
Thanks, --John--
Watch this if you get it wrong you will overheat ASAP.
The Following 2 Users Say Thank You to JeffB28 For This Useful Post:
46FordJohn (09-15-2019), LATECH (09-15-2019)
Old 09-15-2019, 07:07 AM
I checked them over really thoroughly and they have the same exact bolt holes in both ends of each head. That really got me thinking as to what could be the difference and that's why I asked the question. I don't remember any of the books I read mentioning the heads being symmetrical and interchangeable. Thanks for your very valuable input. --John--
Old 09-15-2019, 07:11 AM
Originally Posted by JeffB28 View Post
Watch this if you get it wrong you will overheat ASAP. https://www.youtube.com/watch?v=v9E1GIvw_zs
Thanks for that. I know I got the gaskets on right because they were very clearly marked "FRONT." It is a good thing they were marked otherwise I would probably have gotten that wrong too. Just kidding. I studied that pretty carefully. --John--
