Ford small block carb spacers - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2019, 05:20 AM
jseabolt's Avatar
Got a question. In attempt to control this vapor locking/heat soaking issue, I'm going to also install a plastic carb spacer on my 68 Fairlane.
I've got two carburetor spacers. The brown one I picked up at a car show and the other one is unused, I not sure where it came from. I think it came with the rebuild kit I bought 20 years ago because there was another base gasket with it in the ziplock bag. Why I did not install it at the time I have no idea. Maybe I didn't think it was important.
There is already a carb spacer on this car but it is not steel. This should be the part I am talking about. Looks aluminum to me.
https://secure.cougarpartscatalog.com/carbspcr2v.html
Reason I ask is the PVC system vents into a port on the back of this aluminum spacer. There is no port on the plastic spacer for the PVC hose.
So I guess as long as the linkage is long enough I can just place this plastic spacer between the original aluminum spacer and carburetor?
Hopefully the studs are not seized since I'll have to install longer studs. That would open up a can of worms if I were to break one off in the intake manifold. So I'll need to soak it down with PB Blaster and hit it with a propane torch before attempting to remove them.
It may be worth trying to just drill and tap this plastic spacer for a PVC port. I've got all the drill bits and tap to do it.
So should I stack the plastic one on top of the factory aluminum spacer and use longer studs or drill and tap the plastic spacer for a PVC port?
ID:	447667   Click image for larger version
Old 09-20-2019, 08:21 AM
RWENUTS's Avatar
Likely not much to be gained with spacer swaps.
Maybe a heat shield would work.
Easy to make from 1/8 inch aluminum plate.
I’ve made them from cookie sheets!
Like this for a Holley 4 bbl.
Your carb studs should be long enough.
https://www.holley.com/products/fuel...s/parts/108-70
Old 09-20-2019, 12:03 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
5,o heat sheild
early 80;s 5,0 Mustangs with the holly 4 barrel had factory aluminum heat shields. I don't know if the 2 barrel cars used them I'v only had the H,0 4 barrel cars.
Old 09-20-2019, 12:49 PM
jseabolt's Avatar
I'm not really expecting any HP gains from using one. I've read this plastic spacers help preventing heat soaking.
Old 09-20-2019, 12:56 PM
delawarebill's Avatar
spacer
yes the plastic will be better for less transfer of heat. just drill and hole in the back and tap it..... i had a '66 fairlane a few yrs ago.
Old 09-20-2019, 01:19 PM
ericnova72's Avatar
More for Less Racer
As long as the plastic spacer is solid and not a hollowed out lightweight casting, you can tap it, no problem. Done it before on both phenolic and plastic spacers.
