Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Frame / motor mounts
  #28 (permalink)
Old 05-08-2019, 06:42 PM
chasracer's Avatar
chasracer chasracer is offline
True Hotrodder
Originally Posted by ericnova72 View Post
Engine angle in the chassis means nothing really....all that has to jive together is the trans output and the pinion input.
That's within reason...can't have the engine/trans centerline down 10 and pinion up 10 and have it live for long...to much working angle on the u-joints.
Another good place to check engine/trans angle is the face of the harmonic balancer.
Fuel injection makes it even lees important what the intake top angle is, carbs with floats are the only thing affected there by too much angle.
Exactly ^^^ But you also cannot have a zero angle at both ends of the driveshaft either. U-Joints need a slight angle to work correctly.
