Frame Rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2018, 05:58 PM
Molon Labe's Avatar
Last journal entry: Floors
Frame Rust
Although everything looked fine on the frame of my '67 Fairlane I discovered my driver's front frame rail is badly rusted from the inside out. At first I thought it was just the area ahead of the shock tower but unfortunately it's rusted around the steering box as well. I removed the sway bar bracket and cut open the frame behind it and oddly, it seems to be just the inside of the rail that's bad.
I just discovered this today and haven't had time to think through how I'm going to approach this. The thought of drilling out all the spot welds on the shock tower assembly makes me dizzy but if that's the only recourse then that's what I'll do. If anyone has had to make repairs to this area I'm very anxious to hear from you
Name:	Frame Rust 1.JPG
ID:	418914   Click image for larger version
Name:	Frame Rust 2.JPG
Old 04-12-2018, 08:49 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I see one of three options.
One) Try and find a replacement frame section. Some of the restoration houses that specialize in Ford may have them.
Two) Carefully remove the frame section so you can use it as a pattern to make your own replacement frame section.
Three) Just bite the bullet and make a forward frame half from box tubing.
Which one to do? It depends on how close to original you want to stay.
My thoughts on the subject..
Sam
Old 04-13-2018, 08:00 AM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
In Upstate NY, you had best look at everything underneath that Fairlane. They have been known to literally break apart at the firewall'
You can do as Sam notes above.
You can go 'big time' from sellers like here: 1966-67 Ford Fairlane REVO chassis - Roadster Shop Roadster Shop
or, restore from places like here:https://www.carid.com/ford-fairlane-chassis-frames/
When I sold my '68 (virtually the same chassis as a '67, it had a rotted front frame at the firewall ... and that was about 1978!!!!!
Dave W
Irelands child
Old 04-13-2018, 04:29 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Mustangs Unlimited, and others, have any part you want to repair that, from just 1 of the main frame parts to a complete apron/frame assembly. The frame rails are actually 2 pieces, spot welded together and extend back to the firewall, there is another extension of the frame that goes under the floor pan and seat pedestal. Like Ir elands Child said, inspect the frame very closely from the core support to the floor pan. I would not be surprised if you find more rust that may be hidden by previous sealer, filler, etc. Those cars rust BAD in a salt state. Here are a couple pics of just 1 of the half dozen
Mustangs I've rebuilt the past few years.
Actually, here's the link to all 200+ pics of the restoration too...
1968 Mustang by Mitch | Photobucket
The left side wasn't as bad and I fabricated a reinforcement for the inner rail from a piece of heavy wall tubing.
We bought the outer rail and sectioned that in, as the rust stopped right at the tower.
The Following 2 Users Say Thank You to Too Many Projects For This Useful Post:
64nailhead (04-14-2018), idrivejunk (04-13-2018)
Old 04-13-2018, 05:31 PM
Molon Labe's Avatar
Thanks for the feedback. I may have panicked a little when I found out how extensive the rust was yesterday. My biggest concern was that highly stressed members like the shock tower and cross member are all coming together on a rusty frame.
I've checked the rest of the car and there's no other rust in the frame, torque boxes (already replaced the driver's front box), rockers, etc. I thought I was done with rust that's one reason this was such a shock. I also had to replace all the floors.
I cut out the rust until I got to solid metal. The outsides of the frame and top are good with only surface rust. The bottom of the frame has rust pits. I'm going to make a 12" long 14 ga. patch to go into the frame behind the shock tower/cross member and weld those parts to the patch then the patch to the inside top and bottom of the frame. Then I'll fab up some "L" shaped pieces to weld to the top inside corner of the frame, down the inside and under the bottom. I'm not concerned about originality - just safety and having a sound structure.
Name:	Frame Rust 5.JPG
ID:	419002   Click image for larger version
Name:	Frame Rust 4.JPG
Old 04-13-2018, 05:43 PM
Sounds like a good plan. Don't forget the spacers in there for the steering gear bolts...
Old 04-13-2018, 05:59 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
I would have replied sooner but didn't know Mustang stuff was the same. Thought of asking if you can use Mustang parts. Heres pics of a previously cobbled 70 rail (wrong dide though) that I did around five years ago with a scrap of what they call around here "red iron":
ID:	419018   Click image for larger version
ID:	419026   Click image for larger version
ID:	419034   Click image for larger version
ID:	419042   Click image for larger version
ID:	419058   Click image for larger version
ID:	419066   Click image for larger version
Old 04-13-2018, 07:49 PM
Molon Labe's Avatar
Nice work you guys. Yes, the supports for the two forward steering box mounting bolts were toasted. I plan to weld tubes back in. Also, a friend suggested a tower brace for a bit more stiffness. Sounds like a good idea.
The Following User Says Thank You to Molon Labe For This Useful Post:
idrivejunk (04-14-2018)
Old 04-13-2018, 07:53 PM
Molon Labe's Avatar
Hey, Idrive, I just realized the area you showed being repaired is behind the shock tower. How difficult was it getting all that and the cross member off to make the repair?
Old 04-13-2018, 08:38 PM
idrivejunk's Avatar
Grand Prix User
It would be much more pleasant on a rotisserie, thats for sure. If memory serves me... after the bolt in crossmember was out I just got happy with a plasma cutter to get the bulk of it cut away. Being how the rest of it, getting the stumps off the rail cleanly with least hot metal on your elbow pit and in your face...is inherently unpleasant, this would have been my approach:
Sand metal to reveal spot welds
Sharp punch marks centered on spot welds
1/8" pilot divots (drilled to, not through, the rail) on punch marks
Gentle usage of cheap Blair spotweld cutter (double sided hole saw thing with spring loaded pin in middle) to the rail, erring to the side of caution as to not cut rail
3M 1990 or equivalent "the rock" (weld grinding wheel like a thick cutoff wheel) to thin out each weld.
Hammer and sturdy panel separation tool, more rock. I use a solid metal house painter's three way tool. Its for baseboards and trim.
I think thats how it went. Looks like I did not get pics of the upside down rail work but my folder is as big as Mitch's and I get lost.
The Following User Says Thank You to idrivejunk For This Useful Post:
Frame Rust Mac88 Body - Exterior 4 04-28-2013 05:02 PM
Rear window frame rust, windsheild rust cpratt Body - Exterior 5 09-18-2008 03:41 PM
frame rust k.c. Body - Exterior 5 04-12-2008 11:14 AM
Frame Rust Beenawhile Introduce Yourself 1 12-24-2004 07:46 PM
frame rust out. rhett General Rodding Tech 1 07-17-2003 02:36 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
