Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fresh Valve Job, now engine won't turn! What the heck?
Old 04-07-2011, 11:26 AM
91CamaroDude 91CamaroDude is offline
sounds like you might have a timing tooth off. my motor was on a test stand, tried to fire it up, turned out the timing on the cam to crank was off 180 degrees. got that fixed, put it on TDC, thought it was firing on #1, and it was having a REAL hard time turning over. then found out that i was too far advanced. adjusted it one time retarded. baby fired right up
