Front Brake convertion kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2015, 12:50 PM
jeffmc's Avatar
jeff mc
Last journal entry: 1941 Dodge Custom
Hello All
As I said in my first posting ( general section)Ive got a vibration on the front drivers side .Shop said everything good except wheel bearings.
Changed wheel bearing ,had tires re balanced and still have the vibration.
So I pulled everything apart and started checking myself ,everything feels good to me.Also pulled disk so I could check spindles .The drivers side mics 1.743 ,checked the bearing and it mics 1.749.Being a machinist I think that is way to much clearance,but never built a car before maybe not.
I think there is a drop spindle and I know there is a after market disk brake kit on the car. I believe when I got the car his buddy told me there was a drop spindle on it .
Can anyone ID any of this ? brake kit,spindle .
Also its a 1941 Dodge D 19 Custom
PS There is 7 inches between bolts to mount the brake caliper. Read some where thats how you ID the caliper.
PSS There is no number or markings on any thing .
ID:	226050   Click image for larger version
ID:	226058   Click image for larger version
ID:	226066   Click image for larger version
ID:	226074   Click image for larger version
Old 06-12-2015, 09:24 AM
1971BB427's Avatar
Got a picture of the caliper also? I see numbers and markings on the hub of the rotor. MINTHK 5007 and 885IN. Might do a search of various brake catalogs, and see what it fits. Also a bolt pattern for your hub will help narrow it down. A Ford or Mopar if it's 5x4.5", or Chevy if it's 5x4.75" I doubt it's Chevy or GM, as it doesn't look like any of the GM hubs.
The Following User Says Thank You to 1971BB427 For This Useful Post:
jeffmc (06-12-2015)
Old 06-25-2015, 11:01 AM
LBL's Avatar
LBL LBL is offline
Running Down the Road
Last journal entry: Interior
A Thought
I have no idea what you have on for wheels but I once had a vibration that came from a self tapping bolt that I used to hold the center cap on the rim. It had too big of a head and caused the rim to stick out a bit at that point. Just a thought to check the back of you wheels and make sure that nothing is out of the normal there ...
The Following User Says Thank You to LBL For This Useful Post:
jeffmc (06-25-2015)
Old 06-25-2015, 11:14 AM
jeffmc's Avatar
jeff mc
Hello All
Update on the vibration problem. I pulled both sides off and mic ed everything.Both sides mic the same so I do not believe its a bad spindle.
I have found out they are gm calipers.
Also tighten the wheel bearing up a little tighter ( maybe too tight ,don't have a torque wrench ,going to get one soon) .It took some of the virbration out but not all of it .
Switched tire from passenger side ,still the same.Going to check the back side of the rims for flatness.
A few things guys have told me ,,,warped front disk???,,,Drive shaft out of balance ???
Any ideas or help would be great !!
Posted some new pics also.
Jeff
ID:	228346   Click image for larger version
ID:	228354   Click image for larger version
ID:	228362   Click image for larger version
ID:	228370   Click image for larger version
Front Brake convertion kit jeffmc Suspension - Brakes - Steering 1 05-29-2015 04:44 AM
Disc brake convertion 72 chevelle chevy power 1972 Suspension - Brakes - Steering 3 11-13-2009 07:24 PM
Conversion Brake Kit djdress Suspension - Brakes - Steering 3 01-31-2005 06:01 AM
Speedway brake kit adtkart Suspension - Brakes - Steering 2 01-11-2004 06:11 PM
Disc brake kit? Bo_Jangles Suspension - Brakes - Steering 0 06-25-2003 06:22 PM
