You need a break pressure gauge. This will let you check pressures at the master cylinder, portioning valve, and the wheel cylinders individually to see where your blockage is. It is alot of bleeding. But it works to find where your issue actually is.
You run a flexible hose to the gauge then use a male to female fitting to screw it into the section your testing.
