front drum brakes have no flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2015, 02:18 PM
I recently rebuilt the master cylinder in my 1955 ihc. Bench bled and installed it, new wheel cylinders on all for corners. Went to bleed today and the rear lines pressured up just fine, went to the fronts and all I get is air out of both sides, no fluid at all and the fluid level in the master does not move. Any ideas? What did I do wrong? Really wanted to drive this out of the shop today.
Old 07-18-2015, 02:22 PM
Old 07-18-2015, 04:31 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Homemade Motive type power bleeder for $14 - Page 2 - Corvette Forum
Here is a discussion of a home made brake bleeder which may help you out.. I have found it can try ones patience with the ole pump up and hold em routine when the lines are dry..
Sam
Old 07-18-2015, 05:36 PM
I was able to get fluid moving by disconnecting the front line at the master and putting my finger over the port, pumping the pedal to create vacuum and walk it started flowing.
Ford front drum brakes (couple of questions) jseabolt Suspension - Brakes - Steering 20 05-13-2015 11:06 PM
67 lemans front drum brakes 18436572 Suspension - Brakes - Steering 2 06-05-2014 09:52 PM
37 plymouth front drum brakes crawler Suspension - Brakes - Steering 1 07-24-2011 11:01 PM
Front Disc Rear Drum Brakes bigjoedo Suspension - Brakes - Steering 2 07-02-2004 11:16 AM
front brake diagram drum brakes 72chevyelcamino Suspension - Brakes - Steering 0 10-28-2002 03:17 PM
